Previous in Forum: ASTM A395 Annealed Ductile Iron Casting - "wild" % Nodularity Values   Next in Forum: Analysis of Producer Gas from Bituminous Coal
Time Taken
12/28/2011 10:59 AM
hello everybody,
i needs help, how to determine/know the time taken for teflon@PTFE to expand at certain temperature. lets say at 500 degree celcius, what time for teflon@PTFE to take for it to expand about 1mm.
if there have a formula to determine this problem? or the standard table to be refer?
thanks engineer!!
Re: time taken
12/28/2011 11:15 AM
PTFE has a melt point of 327°C.
Please reconsider your parameters and restate your question.
Re: time taken
12/28/2011 11:22 AM
Thermal expansion is the amount something grows as heat is added, or removed.
Everything does it but the rate is different, depending on the material. Typical rates for polymers is around 50-100 parts per million.
Coefficients of Linear Thermal Expansion
Re: time taken
12/28/2011 11:22 AM
Your looking for dimensional stability.
Check manufacturers specs.
The distributors (websites possible) should have a table on the physical/mechanical and thermal properties on it.
Re: Time Taken
12/28/2011 11:57 AM
thanks everybody for ur cooperation!!
Register to Reply 4 comments
daniel007 (1); Doorman (1); lyn (1); phoenix911 (1)
