Previous in Forum: GIS   Next in Forum: Motor Running Than Rating Speed
Busway
12/28/2011 2:18 PM
Is there a way to you verify busway is size properly from a power riser diagram?
Pathfinder Tags: busway
Re: Busway
12/28/2011 5:21 PM
Yes. Do this proper calculations required by the code you are under.
Re: Busway
12/29/2011 8:44 AM
Thank you wareagle
Re: Busway
12/29/2011 12:58 AM
They should give the short circuit level and connected load to calculate.
pnaban
Re: Busway
12/29/2011 8:48 AM
Okay. so a 2000A busway should be equal or greater than the some of the total amperage feeding of that busway?
Good Answers: 170
Re: Busway
12/29/2011 4:36 AM
Verifying the bus way size is not possible from a power raiser diagram as such a power raiser diagram would only be a GA (General Arrangement) drawing. You at at least need an SLD (Single Line Diagram) for the same.
Re: Busway
12/29/2011 8:45 AM
Thanks
Good Answers: 102
Re: Busway
12/30/2011 12:23 AM
Search for "conductor size selection" on the internet.
There is as little or as much knowledge as you need there including selection criteria, practical considerations, procedures and standard tables.
Lots of holiday reading....
Register to Reply 7 comments
elaud (3); electricalexpert65 (1); pnaban (1); Wal (1); wareagle (1)
