Previous in Forum: Nocolok Flux powder   Next in Forum: Removing Moisture from Biogas Pipelines
Brittle Springs
05/01/2007 2:49 AM
Dear All,
Is a Cr-Si steel spring with high Chrome-Silicon levels will become crunchy or easy cracked under fully extension ?
Regards,
Tata
Good Answers: 50
Re: Brittle Springs
05/01/2007 11:43 PM
Just for what it's worth, The only experience I've had with this type of steel is if you get it hot (even through internal-friction) it eventually becomes brittle.
Re: Brittle Springs
05/02/2007 7:40 PM
Dear Tata the problem its not for de Cr or Si; the brittle depend, if the wire it's hardning from coold work or heat treatment and the quality of this process; beside the inclusions no metalic into the steel, from steel making process. I'd recomend to anlized the break surface, in general could give you same clue. I hope to help you, don't hesitate to contact ccvallino@hotmail.com-
You might be interested in: Flat Springs, Power Springs and Spring Motors
