Previous in Forum: Brittle Springs   Next in Forum: Has Anyone Tried FIREPOWER Fuel Conditioner?
8 comments
Removing Moisture from Biogas Pipelines
05/01/2007 3:01 AM
Hallo
Can somebody suggest method to remove / reduce moisture contents from biogas pipe line. The relevent data is as under:
Biogas pressure: Few mBars.
Climatic conditions: Daily temp. variation -- 23 deg. to 33 deg.C.
Relative humidity: around 70%.
Thank you.
Good Answers: 32
Re: Removing Moisture from Biogas Pipelines
05/02/2007 12:18 AM
Using moisture trap or moisture absorbing materials you can reduce the moisture from gas. Look at things that will not absorb your gas but will absorb only moisture. you can also use gas dryers.
Popular Science - Weaponology - Cardio-7
05/02/2007 8:27 AM
Is the pipeline "empty" (does not contain biogas) when you need to remove moisture? If so, use dry air (less than minus 40 degrees dew point), which you can recycle thru any of a number of moisture removing/dehydrating agents, Dryrite, etc. You may also be able to place a quantity of moisture absorbing agents in the pipeline while it's carrying the biogas, for continuous moisture removal. Go to Google or the Handbook of Chemistry and Physics for a table of drying agents and their efficiency. Dryrite used to publish a booklet listing various drying agents and their efficiency. If necessary, use dry nitrogen to eliminate contamination. Probably not an option, but a third process would be to draw a good vacuum on the pipeline.
05/02/2007 8:29 AM
On a biogas pipeline this unique filter will work wonders with a spin-on filter head. Here is the first part of the MSDS.
MATERIAL SAFETY DATA SHEET
SECTION I - CHEMICAL PRODUCT AND COMPANY INFORMATION
H2O Control Products Inc.
2204 Algonquin Road, Sudbury, ON P3E 4Z6
PRODUCT TRADE NAME:
H2O CONTROL – Fuel, Hydraulic and Air Filters
CAS NO: Not applicable
SYNONYMS: None.
GENERIC/CHEMICAL NAME: Water & particulate removing filter
PRODUCT TYPE: Spin-on or cartridge type filter
PREPARATION/REVISION DATE: January 8, 2007
________________________________________________________________________
SECTION II - COMPOSITION/INFORMATION ON INGREDIENTS
H2O Control Filters are spin-on and cartridge style. The water absorbing media contained within the filter is one of a number of super absorbent polymers, all of which are listed as non-hazardous and non-toxic.
________________________________________________________________________________________________
SECTION III - PHYSICAL AND CHEMICAL PROPERTIES
STANDARD PSI RATING: UL approved for 150psi when filtering hydraulic/industrial fluid and air.
FUEL PSI RATING: UL approved for maximum of 50psi when filtering petroleum products such as diesel, gasoline, ethanol blends, methanol, etc.
Good Answers: 32
05/02/2007 9:37 AM
Sounds that you have suggested almost the right solution. What else is needed? Good.
05/04/2007 4:20 PM
70% relative humidity? It seems like a lot of drying agent consideringthe volume rate you would need to treat. What temperature is the biogas evolving at? Maybe cool the vapor and separate "trap" the liquid moisture off first to remove a portion of the higher humidity content, then use a drying agent to remove a majority of the remain moisture.
Good Answers: 32
05/05/2007 12:07 AM
Yes, This sounds much better idea. There is high humidity in biogas reactor as it is hot on continuing reaction and tank is full of water and no way for moisture to escape. A cooling trap will sure condense water and most part of the biogas may still remain as gas with some air. Normally biogas burns even with so much water in it but will work better if water is reduced. Let me see the optimum temperature reduction for the biogas reactor gases to get rid of moisture.
It looks to me that biogas reactor works much better in hot condition and optimum pH is 6.8 to 8 or slightly acidic to slightly basic where pH 7 is neutral for water.
Read more here
http://www.mothercow.org/oxen/gobar-gas-methane.html
05/07/2007 12:17 AM
For reducing the moisture, pipe trap seems to be cost effective solution. Any idea about the shape and size of trap? Even the location of trap seems to be important.
10/07/2014 1:07 PM
but we are make flexible biogas for those people who r not able to spend more cost so please give me the idea which give better result without affecting cost
Anonymous Poster (3); Cardio07 (1); gogatedn (1); Shyam (3)
