Would someone please help me with the following.
This is an oil field topic regarding connecting 2 drill pipes or casings together with a buttress connection.(stabbing/tripping in)
- How is it ensured that there is no damage when male/female threads connect?(galling or cross threading) I understand there is copious amounts of lubricant/sealer on the threads prior to lowering down and connecting a heavy joint to help matters and to promote sealing. However this surly cannot compensate for a heavy stand bumping down onto the start of the thread (weak point) and causing damage.
There seems to be no industry part available off the shelf for a HP quick connect for a 9-5/8" pipe. Therefore I have been tasked to design a quick connect coupling using a buttress thread to ANSI B1.9 for a 9.625 o/d pipe/casing. With some back ground investigations I find the connection is a 1 on 16 taper. For my connector I will be using 3 TPI and a 3 start thread and a calculated full thread requirement of 18 teeth for load conditions giving me 3 turns for connection.
With a taper connection the first few male threads will pass into the female before a turn is required thus making an even quicker connection.
My concerns are the initial bump onto the threads (Question 1 above) where they are just forming (not full depth)
If anyone can provide some insight/advice/pointers/websites etc I would be very grateful.
Thank you
