Previous in Forum: Hazardous Area Equipments   Next in Forum: Insulation Materials for HVAC Equipment
Valves Specs
01/04/2012 7:44 AM
What is the different between max working pressure for the valve and nominal pressure (PN)???
Pathfinder Tags: s valves spec
Re: Valves Specs
01/04/2012 7:52 AM
About 33%.
Re: Valves Specs
01/06/2012 12:06 AM
nominal pressure would be the pressure rating under normal circumstances. maximum pressure is normally the pressure that the valve will tolerate in case of a malfuntion.
Register to Reply 2 comments
