Previous in Forum: ASME B 16.34   Next in Forum: Grand Father Clock
Solid Flange Design Calculation
01/07/2012 2:45 AM
I am designing a non standard flange with below duty Conditions & parameters -
1> Flange ID =3300 MM
2> Pressure = 1.5 Kg/Cm2
3> Temperature = 600°Celsius
4> Flange Rating = Class 300
5> Service = Hot Oil
As per the standard calculation ASME the Flange thickness is less.
The equipment is very old & the orignal flange is having thickness = 125 MM , Number of bolt = 112 & Bolt Diameter = M27.
Flange is of Solid Flange with no weld neck design. I am not able in correlating the design calculation & the physical dimension of Flange.
Can anyone tell me the Flange Thickness =? , Bolt PCD = ? Gasketing Seating Area(CAF) = ? , Bolt Diameter =? with farmulae to help me better understand.
Pathfinder Tags: Flange Design Formulae
Good Answers: 183
Re: Solid Flange Design Calculation
01/07/2012 5:04 AM
What type of joint ? Gasket ? O-ring ? The bolts position and the flange dimensions are depending on it. The thickness of the part on which the flange is welded is also an important factor since its stiffness plays a role in the required flange stiffness.
Of course for not standard flanges for which all those criteria have been considered already for design.
01/07/2012 6:22 AM
SPiral Wound Gasket or Compressed Asbestos Gasket
01/07/2012 8:15 AM
Subaru....
Hot oil at 600 degrees C..??? Really ?
This is hotter than many Main Steam Systems at power plants
What kind of oil is this ??
Good Answers: 183
01/07/2012 3:04 PM
You are right to make the remark ! I did not look at the values, at such a temperature oil will be destroyed. The molecules do start to break at over 200°C.
01/09/2012 3:40 AM
OK. So is the original posting incorrect? What is the process maximum temperature and pressure?
01/08/2012 11:37 AM
Data given seems some un onable. Flange ID 3300mm hot oil at 600°C at 1.5 kg/cm2 seem impossible with flange class 300.
Some corrections are required from OP side.
Temperature may be in °F, Pressure shall be little higher etc.
Register to Reply 6 comments
Anonymous Poster (1); Mukesh0861 (1); nick name (2); PWSlack (1); subroto24chatt (1)
