Previous in Forum: HTML CSS Javascript   Next in Forum: CMMS - Visual Plant
12 comments
What is the Purpouse of Usin Micro Contoller in Autonomous Robots?
01/08/2012 10:01 AM
I want to know what is the role of micro controller in autonomous robots?
Re: what is the purpouse of usin micro contoller in autonomous robots?
01/08/2012 10:11 AM
To contol the robot.
Good Answers: 918
01/08/2012 10:17 AM
How do you think they get to be autonomous?
Perhaps this will make more sense. Ask, what is the purpose of the brain in a human?
01/08/2012 10:18 AM
How would you do it?
Re: What is the Purpose of Using Micro Controller in Autonomous Robots?
01/08/2012 12:33 PM
The real purpose of a micro-controller in an autonomous robot is to baffle a novice what the robot can and will do. If this is a homework question, we don't do students homework here. If this is not a homework question, your question appears to be so naive that I doubt you'll recognize the difference between a good and a bad answer here.
Re: What is the Purpouse of Usin Micro Contoller in Autonomous Robots?
01/08/2012 2:16 PM
Autonomousnos...
SWARM ROBOTS...
01/09/2012 7:34 AM
I loved all the answers Guys, I feel you held yourselves back very well, congratulations.
I don't know personally what "deps" means, but in German (we are multi-language here), you don't want to be called a "Depp", which I am sure sounds similar, its not nice as "Depps" are known for asking stupid questions!!!!
Here is the dictionary page I was looking at:-
http://www.dict.cc/?s=Depp
See what I mean?
I think a rapid name change could/should be in order and fully acceptable to all on CR4.....
Good Answers: 918
01/09/2012 7:43 AM
Ouch!
01/09/2012 8:02 PM
You don't think that this is why this guy's last name has two p's?
01/10/2012 8:48 AM
I can only say he is a far, far better actor than his name in German suggests......I like all his films that I have seen except one, but even that one has him acting brilliantly, just the subject matter was questionable....
There again, 60% of all US people originally came from Germany in one way or another and many have forgotten the original meaning of their names....and/or the spelling has been changed or something.....
01/09/2012 9:34 AM
We use them to keep humans from making stupid mistakes.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
01/09/2012 10:23 AM
Because a super computer would squash the little guy...
It's not Rocket Science
Good Answers: 75
01/09/2012 9:04 PM
Fun answers, all. But I'm going to go out on a limb, and make an assumption, that the OP is asking why a MicroController, vice a more conventional MicroComputer. Note that my assumption is based on a MicroController being recognized as a device optimized with more I/O CONTROL capability, as opposed to the MicroProcessor, optimized for more Data I/O throughput. Both may have a fairly prodigious computing capability, but one is more built to collect and cogitate, while the other, the MicroController, is more designed to collect and preform actions upon, data.
If that is true, my answer would be "to implement the primary program control loops in sensors, with the resulting data being parsed, and reacted to, as a secondary function" (such that the robot, when it's UltraSonic sensor detects a void in front, doesn't need to cogitate about what to do, since it's hard-wired response is to back away, turn, and try another route) as opposed to a more software intensive "look ahead, map obstacles, determine a path, recheck for clearance, THEN move forward". One requires a lot more processing power BEFORE commitment to a motion, while the other is designed in hardware to be more reactive, and expects that movement will uncover obstacles, which can be reacted to AFTER motion has already started.
In a complex environment with many moving obstacles (Urban Robotic Vehicle tests), only the more processor intensive "calculation before movement" paradigm is survivable. But in a "Follow the troopers wherever they go carrying their equipment, assuming they won't go where I can't go, and I'm tough enough to handle getting shot trying, and failing the first try, to follow, if they forget, or are forced into very bad terrain" scenario, less processing might be required, except that needed for things like balance recovery, directional navigation, Identification of Friend or Foe (IFF) and such like. And in a sufficiently complicated application, perhaps BOTH could be employed, to allow for the more mundane, day to day, "go here, but don't fall down there routines" to be implemented in a microcontroller, and the more sophisticated survival routines implemented in a microprocessor, which might have an override capability to stop the microcontroller loops in time to implement or redirect a change in program response.
This sort of Hierarchical Programming, with priority interrupt loops has been used for this early robotics experiments, and probably is today, though I don't have any specific examples.
Register to Reply 12 comments
Andy Germany (2); Anonymous Hero (2); JohnDG (1); lyn (1); micahd02 (1); redfred (2); Rockyscience (1); ronclarke (1); SolarEagle (1)
