Previous in Forum: How to Wire Dual Car Alternators Together for High Current?   Next in Forum: Current Transformers
9 comments
Comments on Short Circuit Calculation Needed
01/08/2012 11:37 PM
Hello everyone. I am new college pass out. I got some electrical drawing and calculated the short circuit but there is variation between my calculation and the contractor calculation. Here I have attached my calculation please comment on it (Not a home work question). I want to know any other factor to be included in the calculations. I made my calculation as per IEC 60909.
22kv Line ,z=1.29,Cmax=1.10 and Cmin=1.0
MAXIMUM SHORT CIRCUIT CURRENT
INITIAL SYMMETRICAL SHORT-CIRCUIT CURRENT =Cmax * 22000/(1.732 * 1.29)
=1.10*22000/2.23
=24200/2.23
=24200/2.23
Ik" = 10852.01A ~ 11KA
PEAK SHORT CIRCUIT CURRENT (Ip) =K * 1.414 * 10852.01 (value of k obtained from graph)
=1.6 * 1.414 *10852.01
= 24551.58 A
MAXIMUM SHORT CIRCUIT AVAILABLE AT 22 KV = 24551.58 A ~25KA
MINIMUM SHORT CIRCUIT CURRENT
INITIAL SYMMETRICAL SHORT-CIRCUIT CURRENT =Cmin * 22000/(1.732 * 1.29)
=1*22000/2.23
=22000/2.23
Ik" = 9865.47A~ 10KA
Should i calculate the first peak of the fault current for minimum fault current (Ip) or go a head with the initial symmetrical fault current Ik" (ie minimum Fault current =10KA)
PEAK SHORT CIRCUIT CURRENT (Ip) =K * 1.414 * 9865.47 (value of k obtained from graph)
=1.6 * 1.414 *9865.47
= 22319.63 A~23 KA
MINIMUM SHORT CIRCUIT AVAILABLE AT 22 KV= 22319.63 A ~23 KA
Pathfinder Tags: Short circuit calculation.
Re: Comments on Short circuit calculation needed.
01/09/2012 12:20 AM
Well it's nothin to be ashamed of, I passed out a few times during my college years....Now what are all these calculations about, transformer, generator, something new?
01/09/2012 1:18 AM
Its about a generator connected to 11 Kv line to export power to 22Kv line tranformer data :12 MVA,z%=8
Spam
01/09/2012 3:44 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 170
01/09/2012 6:47 AM
You have not considered the source impedance and the transformer impeadnce. You ahve only included the line impeadnce. That's why you get the variation. Pl. read IEC 60909 more carefully. It definitely takes intgo account the source impedance and the transformer impedance.
01/09/2012 9:04 PM
Thanks for your reply...and for minimum short circuit current should i calculate the first peak value of the current (Ipmin)?
Good Answers: 170
01/11/2012 7:37 AM
Any short circuit calculation involves calculation of two values, the symmetrical RMS values of the short circuit current (to arrive at the required short circuit breaking capacity of the Short Circuit Protective Devices and to calculate the thermal effects of the short circuit current) and the first cycle Aymmetrical Peak value of the short circuit current (to arrive at the required short circuit making capacity of the circuit switching devices as well as to calculate the electrodynamic stresses developed during the short circuit).
These values (RMS & Peak) have to be calculated both for the minimum short circuit current as well as the maximum short circuit current. The minimum and maximum values of short circuit current mentioned in the Standards are pertaing to certain assumptions that may prevail during the short circuit.
01/09/2012 8:15 AM
Dear friend,
please teach me. i am also intrest in short circuit calculation. what is the graph for K value, what is the 1.414 value. please replay me. or send by mail. PEAK SHORT CIRCUIT CURRENT (Ip) =K * 1.414 * 10852.01 (value of k obtained from graph)
Regesh kumar.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Regesh kumar
01/09/2012 12:21 PM
Please do not expect us to provide you with a free education. Do some basic research ON YOUR OWN!!!!!!!!!!!!!!!!!!!!
Good Answers: 19
Re: Comments on Short Circuit Calculation Needed
10/06/2012 2:16 PM
Please try this link
Ramesh,Freelance Electrical/automation Consultant
Register to Reply 9 comments
brookdai (1); electricalexpert65 (2); lyn (1); ramvinod (1); regesh137 (1); SolarEagle (1); sriram1988 (2)
