Previous in Forum: Motor Rating for Electric Vehicle   Next in Forum: Voltage of Fuel Sender/Float
11 comments
Why Seven?
01/10/2012 6:02 PM
I see some automobile manufacturers use seven spokes or segments on their wheels and wheel covers. Why seven? It doesn't divide evenly into 360°. It would be a headache to layout.
Mr.Ron from South Ms.
Re: Why seven?
01/10/2012 6:09 PM
Nothing is a headache to lay out or make with CAD-CAM system and CAD everything else in between.
It was different with a T-square and drafting board. Back then we had a saying, never draw more in the morning than you can erase in the afternoon.
I'll bet some style guy wanted 7. Probably because he think chicks like it.
Maybe Doorman has 7 spoke wheels on his "chick magnet".
Re: Why seven?
01/11/2012 11:53 AM
Naw, I only have three spoke wheels on the chick magnet...
The other one is a moonie, and the spare is a plain steel wheel (but it's flat).
Good Answers: 179
Re: Why Seven?
01/11/2012 8:02 AM
Maybe it just looks good....
Good Answers: 58
Re: Why Seven?
01/11/2012 5:32 PM
My guess is it's more flexible to have an odd number of spokes. Many of these wheels have cast parts, and castings are more brittle than stamped steel. A wheel has to take the abuse of potholes and speed bumps.
mike k
Re: Why Seven?
01/11/2012 5:47 PM
"A wheel has to take the abuse of potholes and speed bumps."
And don't forget the flaming idiots behind the other wheel.
Re: Why Seven?
01/15/2012 10:56 AM
English Monark = 7 point star / David Shepard = 6 point star (Male) / State (Female) 5 point star / Intersection = 4 point star / Pyramid = 3 point star.
Re: Why Seven?
01/15/2012 11:16 AM
P. S. : Intersection = Center of North. South, East & West. (Self)
Re: Why Seven?
01/15/2012 1:40 PM
I admit a 7 pointed star or any design with 7 spokes or sectors can be laid out using a CAD program, but actually laying it out manually from the CAD generated dimensions, will always be very approximate. It could be done without manual layout with a CNC machine, but how would it have been done before computers?
The only thing I could think of would be to discourage copying such as a sherrif's badge. 360° divided by 7 = 51.42857143°, a number difficult to measure and layout.
Re: Why Seven?
01/15/2012 3:07 PM
In the Automotive Blue Printing Manual, has a Degree Wheel of 360 Deg'sl Set it on a large Poster Paper,sheet. The Center to the Dot in the middle of the paper. Make a Dot each 51.5 Deg. Than Make a Line from center to each Dot. ( where do you get the Deg. Symbol, on the key bord?)
Re: Why Seven?
01/16/2012 9:13 AM
"( where do you get the Deg. Symbol, on the key bord?)"
Bert, you can get one two ways:
You can superscript the letter 'O' or a zero, or you can hit the Omega key (Ω) on the CR4 toolbar for a special character selection. The degree sign is available there.
I understand some browsers don't have the entire CR4 toolbar enabled.
Re: Why Seven?
01/16/2012 12:09 PM
ISKY Cams: Gardena Calif. Has the deg. wheels Ph.# 323 -770-0930.
Register to Reply 11 comments
Bert Cundle (4); CaptMoosie (1); Doorman (2); lyn (2); mike k (1); ronseto (1)
