Previous in Forum: Engineering Solution   Next in Forum: Earthing
Motor Power
01/11/2012 12:47 PM
on what a factor a motor power (kw or hp) is depended... if someone says on size then it is wrong becaz i observed many times a small motor in size has more power in kw than large size of motor
Re: motor power
01/11/2012 1:00 PM
The amount of current drawn under full load...Amps times volts = watts
1 hp(I) = 745.699872 W
New Zealand - Member - Kiwi
Good Answers: 29
Re: motor power
01/11/2012 2:19 PM
Only if you can live with the inaccuracy introduced by ignoring power factor.
Power = V x I x Pf
paulusgnome
Re: Motor Power
01/11/2012 4:53 PM
Among other things, the motor rpm and frequency affect its hp considerably in relation to its size.
Register to Reply 3 comments
Paulusgnome (1); SolarEagle (1); Tornado (1)
