Previous in Forum: Motor Power   Next in Forum: Cable Insulation
Earthing
01/11/2012 1:16 PM
How Automobiles/vehicle are being earthed?
peace.
Pathfinder Tags: automobile earthing
Re: Earthing
01/11/2012 4:53 PM
Through the flux capacitor. Unless you have a Cavalier, then there is no earthing, that's what makes them so reliable
Good Answers: 11
Re: Earthing
01/11/2012 6:32 PM
Many years ago when you touched an automobiles that had recently been driven, sometimes you would be shocked by static electricity.
The tire manufactures started putting carbon in the tires to earth the cars and prevent shocks.
Re: Earthing
01/12/2012 12:44 AM
There were 2 methods of connecting metal frame to terminal of the battery,positive as well as negative
pnaban
Re: Earthing
01/12/2012 3:26 AM
See that braided strap wotsit going from one terminal of the battery to the vehicle's chassis? OK? That's it.
Unless it's about the conductive dangly thingy that goes from the vehicle's bodywork and grazes the ground at intervals to discharge static? That could be it. It might need changing at intervals as is wears.
Re: Earthing
01/12/2012 8:26 AM
It's a floating earth. It's better than being mooned.
Good Answers: 58
Re: Earthing
01/12/2012 8:51 AM
One 3/4" X 10' copper clad driven rod.
A $hit load (depending how far you want to travel) of #3 THHN bonded to the driven rod and vehicle frame.
Re: Earthing
01/12/2012 10:39 AM
I think it'll take two loads.
Register to Reply 7 comments
Carl Pugh (1); JWthetech (1); KJK/USA (1); lyn (2); pnaban (1); PWSlack (1)
