Previous in Forum: Excel - Text to Columns Issue   Next in Forum: PIC Program for Controlling Servo/Stepper Motors
10 comments
Good Answers: 109
Mathcad Nonlinear Second Order Differential Equation?
01/11/2012 3:47 PM
Hi to experts,
I got some principal information that it is possible to solve NL Diff.Equations with mathcad.
But I have no idea how to proceed and nobody could tell me.
The equation is: p'' + p'²/p = K
This describes the compressible squeeze film damper of constant film thickness and constant channel width. The pressure along a streamline is p(x). The constant K is a function of gap, viscosity and approaching velocity. Isothermal flow for this moment, may be extended later to isentropic flow.
Also nonconstant channel dimensions to be introduced later.
Anybody who can help? Thank you
RHABE
Re: Mathcad Nonlinear Second Order Differential Equation?
01/11/2012 4:10 PM
This goes through ordinary and 2nd ord, I think this is what you want...
http://learningexchange.ptc.com/tutorial/96/solving-an-ordinary-differential-equation-using-mathcad
Good Answers: 109
01/13/2012 4:16 PM
I tried in the 3 different versions given in Mathcad-help for ODEs.
But none works.
I can try to post the scripts here - tomorrow.
Thank you for your help
RHABE
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
01/21/2012 1:01 PM
Solar Eagle,
Thanks for that, I am on the brink of buying a Version of MathCad, probably 15 as it will also have the PRIME extension. Your contribution is welcome as I have been havering for a while as I was not convinced that there was good support. You have just shown me that there is.
Thanks very much.
Sleepy
Good Answers: 109
01/22/2012 5:50 AM
Sleepy,
before Mathcad I tried Maple, Mathlab and Mathematica but none did fit my thinking as good as Mathcad.
Mathcad has severe limitations - especially as I did not buy the regular support and support I have no access to the discussion forum.
For some weeks I used the free trial version and then a friendly customer came by and dropped and official version - good for me and him.
RHABE
01/22/2012 12:37 PM
Thanks very much for that,
Wolfram has also opened up it's shop in a much more adventurous way.
You can now accesss both Maths and Astronomy through apps on your iPad type device and I am beginning to expreiment with PC Access.
This should provide a much more powerful system. Steve that his site uses a larger server farm than googles!!
Have a go and stay in touch please..
Sleepy
01/13/2012 12:14 PM
You want solve with mathcad or anyway?
01/13/2012 3:34 PM
If p(t)=t², K=6.Perhaps p means polinomial and all this is a joke, is it? course i am not interested in giving you the general solution now.-
Good Answers: 109
01/13/2012 4:13 PM
I have Mathcad but nothing else.
p is p(x) or p(r) the pressure profile in the direction of a streamline between two approaching longitudinal (x) or circular (r) plates if an ideal gas is compressed.
RHABE
01/13/2012 6:49 PM
Did you even test the given solution? Did you try a new one based on? I think would help you find more if you write your eq. as d²(½p²)/dx²=k•p .I would forget computers at this stage of your work.-
Good Answers: 109
01/22/2012 5:42 AM
Ferquiza,
theoretical work is outside my possibilities.
Not only because I tried that only as student but this problem with damping by a compressible squeeze film damper is only one of 20 other problems.
So there is no time available for principle work.
In addition an extension to nonconstant gap and width has to be made and I doubt that there will be a closed solution.
thank you for your help
RHABE
Register to Reply 10 comments
ferquiza (3); RHABE (4); Sleepy (2); SolarEagle (1)
