Previous in Forum: Magnetic Pots?   Next in Forum: Whatever happened to:
Another Space Heater Question
01/18/2012 2:18 PM
My metalworking area of my shop is only 80 sf. I have an 11" lathe and a 6 x 24 mill in there plus all my precision measuring tools. I keep an electric heater running, set to low just to take the chill out of the air. The temp can get down in the 30's overnight. I don't want everything getting rusty. If I use an incandescant bulb instead of a space heater, would that be more economical? The space heater is set at 1200 watts and runs intermittantly while a light bulb would be burning continuously. What size light bulb would work?
Mr.Ron from South Ms.
Pathfinder Tags: heaters
Good Answers: 266
Re: Another Space Heater Question
01/18/2012 3:14 PM
Infrared lamp. Heating the items in the room before the air. Which would place the tools temperature above dew point so no condensation if that's the problem.
Good Answers: 58
01/18/2012 3:14 PM
How about a 120 volt, 150W heat lamp?
We use these in the barns during the winter to give the critters a warm place to go.
80 SF, I imagine you could get by with one, maybe two.
There are a few things to consider first, ceiling height and insulation value of walls and ceiling/roof.
Just a thought.
EDIT - Yea, what ozzb said
01/19/2012 9:48 AM
Instead of just heating, why not dehumidify instead?
01/19/2012 1:32 PM
I would consider anything that was the most cost effective short of a bonfire.
Good Answers: 130
01/19/2012 5:59 PM
Most cost effective for a 'tool room' full of expensive stuff is reverse cycle AC.
34point5 (1); KJK/USA (1); ozzb (1); PWSlack (1); ronseto (1)
