Previous in Forum: Polystyrene Wire Cutting   Next in Forum: Checklist for Overhaul Motor, Rewinding Motor for Electrical Motor
HT Motors
01/19/2012 4:24 AM
Is it essential to provide differential protection on HT motors?
peace.
Re: HT Motors
01/19/2012 4:40 AM
Not if the motor can withstand the arc and ensuing destruction caused by an unprotected internal fault.
These things can be very expensive in terms of replacing equipment and catching up with lost production, so it depends on local economics, really. Also, not fitting the protection can be seen as career-limiting behaviour, particularly in the aftermath of the ocurrence of an unprotected fault.
So it's hardly essential to fit them, though it would be irresponsible not to, perhaps?
Good Answers: 804
Re: HT Motors
01/20/2012 11:00 AM
"... so it depends on local economics, really."
There's the heart of it right there. Differential protection is expensive and runs an increased risk of nuisance tripping if not done correctly, which can cause losses from unnecessary down time. This needs to be evaluated against the risk of additional and/or collateral equipment damage (and associated down time from that) which might have been prevented or ameliorated had DP been used. It requires a cost / risk / benefit analysis to be performed every time.
Re: HT Motors
01/19/2012 5:02 AM
What's an HT motor?
Belgium - Member - New Member
Good Answers: 21
Re: HT Motors
01/20/2012 8:42 AM
HT = High Tension
3.3 kV or 6 kV supply voltage
Good Answers: 170
Re: HT Motors
01/19/2012 5:34 AM
Do a cost-benefit analysis & then decide.
Re: HT Motors
01/19/2012 8:20 AM
Yes.
Good Answers: 244
Re: HT Motors
01/19/2012 8:44 PM
I agree with electricalexpert65. Generally motors of size 1500 hp (or 1100 KW) or larger are installed with differential protection.
- MS
Register to Reply 7 comments
electricalexpert65 (1); JRaef (1); lyn (1); msamad (1); PWSlack (1); rudy.leurs (1); SolarEagle (1)
