Previous in Forum: HT Motors   Next in Forum: Arc Flash Safety (Electrical)
9 comments
Checklist for Overhaul Motor, Rewinding Motor for Electrical Motor
01/19/2012 5:39 AM
Dear all,
Seek our community advice the best and good checklist to perform the repair or servicing electrical motor starting from dismantle from system until complete testing with the system. Please indicate if there is important inspection, monitoring or record parameters need to check and verified during test or installation.......
zhar84@gmail.com
Re: Checklist for overhaul motor, rewinding motor for electrical motor
01/19/2012 5:43 AM
What does the Client's maintenance procedure say?
01/19/2012 5:48 AM
Guvnor - why are you starting this if you don't know what you are doing nor why you are doing it?
Good moaning!
01/19/2012 6:09 AM
hehehe. just need an info if i mistaken or bypass the procedure... now i'm really blurr since i've try to follow the procedure from maker.. but the result for the motor still not in good condition. Why my rotor shaft temperature operate over 100celcius..which will effected to the motor bearing(install as recommended from maker). Any ideas or advice??
zhar84@gmail.com
01/19/2012 6:31 AM
Well, if I were you, Captain, I would pick up the telephone and ring the motor manufacturer. It isn't rocket science!
Good moaning!
01/19/2012 7:37 AM
Have you inspected the rotor of the motor ? If rotor bars are cut then the shaft will be heated up due to shaft current . Or if the bearing outer race is loose , not fiitting in the bearing house tight , then it will rub and create a localised heat which will be on the shaft . In any case you have to dismantle the motor again & do a good inspection.
01/19/2012 8:07 AM
For the bearing housing, it was inspected and insert tightly into bearing housing or bearing seat..Then, what do you meant by cutting rotor bars? is there we make some modification on rotor bar or cut rotor bar for balancing purpose??
zhar84@gmail.com
Good Answers: 181
01/19/2012 10:34 AM
Broken rotor bars can cause current through the shaft and bearings. Very uncommon in modern cast rotor bar design.
To ask about cutting rotor bars shows you don't know what your doing.
01/19/2012 6:39 PM
honestly..yes.. hope all guru can guide me.
zhar84@gmail.com
Belgium - Member - New Member
Good Answers: 21
Re: Checklist for Overhaul Motor, Rewinding Motor for Electrical Motor
01/20/2012 8:33 AM
Did you change the shaft sealing? (zimmerring ?)
When they are new, they heat the shaft more.
Put some grease on it.
60 - 70°C seems a normal temperature to me for a new sealing.
Register to Reply 9 comments
Crabtree (2); PWSlack (1); rudy.leurs (1); TonyS (1); Voltamps (1); zhar84 (3)
