Previous in Forum: Dim Turn Signal   Next in Forum: Automotive
11 comments
Good Answers: 94
European Change To Unleaded Petrol.
01/19/2012 10:35 AM
EU rules mean that from the beginning of 2012, standard unleaded petrol will contain 10% Biofuel instead of the previous 5%. Most modern cars will not be affected but older cars, direct injection & carburetter engines might have to switch to the more expensive premium unleaded. Here is a link to a PDF file which is a combination of an Auto Express article & a list of car compatibility from the Petrol-heads web site.
Re: European change to unleaded petrol.
01/19/2012 10:44 AM
The link doesn't work from here.
Good Answers: 44
Re: European Change To Unleaded Petrol.
01/19/2012 2:44 PM
Gee...thanks...now I'm in trouble
When I visit the host site from your link:
"Access to this site has been denied to safeguard the security posture of the NMCI network.
You are accessing a U.S. Government (USG) Information System (IS) that is provided for USG-authorized use only. By using this IS (which includes any device attached to this IS), you consent to the following conditions:
-The USG routinely intercepts and monitors communications on this IS for purposes including, but not limited to, penetration testing, COMSEC monitoring, network operations and defense, personnel misconduct (PM), law enforcement (LE), and counterintelligence (CI) investigations.-At any time, the USG may inspect and seize data stored on this IS.
-Communications using, or data stored on, this IS are not private, are subject to routine monitoring, interception, and search, and may be disclosed or used for any USG authorized purpose.
-This IS includes security measures (e.g., authentication and access controls) to protect USG interests--not for your personal benefit or privacy.
-Notwithstanding the above, using this IS does not constitute consent to PM, LE or CI investigative searching or monitoring of the content of privileged communications, or work product, related to personal representation or services by attorneys, psychotherapists, or clergy, and their assistants. Such communications and work product are private and confidential. See User Agreement for details."
01/19/2012 2:53 PM
I went riight to the site, no problems.
Good Answers: 44
01/19/2012 4:42 PM
The Navy tends to be conservative when allowing us to access sites that have previously been reported to be associated with unsavory practices...i.e., games, hacking, porn, etc.
Think of it as SOPA for the Department of Defense...we've been living with it for about 10 years now and it really doesn't hurt us.
Good Answers: 94
01/20/2012 2:03 PM
I love that comment, the host site for the file is Microsoft Sky Drive!!!
01/19/2012 9:38 PM
01/19/2012 9:41 PM
01/19/2012 9:45 PM
Me too.
01/20/2012 6:41 PM
We have been using E10 in Germany for at least most of 2011, if not earlier.
There is a list of cars that do not handle it well, even some relatively modern cars do not handle it. But the great majority handle it with no effect other than a slightly increased fuel consumption, which offsets any price savings here anyway.....
If you have an older car, that already has a catalytic converter, it will probably run exactly as before.....
I do not know of any harm done to any motor......I also have not seen a list of any of the symptoms of when it does not work.
I have filled most recent models of Audis, Mercedes, BMWs, VWs, Skodas, Alfas and Opels and not noticed any problems.....all built in the last 6 years or so....
It is a relatively small number of cars in Germany actually affected....
Good Answers: 94
01/22/2012 3:43 AM
The symptoms I have seen reported are rough running & premature engine wear. The E10 fuel is more corrosive than E5 & can damage seal that were not specifically designed to run with it. As you say, most modern cars will be OK but there are a lot of older cars still in use.
01/22/2012 7:25 AM
The seals on some older cars may be affected, but if that is not a problem, then older cars usually run fine......
Register to Reply 11 comments
Andy Germany (2); cuba_pete (2); lyn (2); Nigh (2); PWSlack (1); qaqcpipeman (2)
