Previous in Forum: Selection of Nominal Voltage to Be Used   Next in Forum: Input Output Cables for 560kW VFD Panel
10 comments
Alarm Logic
01/21/2012 2:07 PM
Greetings,
anyone know what is the simple relay logic for 36 inputs alarms with acknowledge and reset and each input has to distribute to 3 different area? hopefullly someone can give sample logic. Thanks
regards,
ivank
Good Answers: 62
Re: Alarm Logic
01/21/2012 2:18 PM
Not the sort of thing I keep in my pocket.
But I'm thinking your first step is to create three legs for the major areas, and then expand it
Re: Alarm Logic
01/21/2012 3:12 PM
Re: Alarm Logic
01/21/2012 3:18 PM
Your operation manual should give instructions....what type of controller?
Good Answers: 181
Re: Alarm Logic
01/21/2012 11:13 PM
Do your own homework.
Give samle logic samples indeed, my son could do that at 12 years old!
Good Answers: 11
Re: Alarm Logic
01/21/2012 11:34 PM
36/3= 12 inputs per area, 12 inputs per circuit, make all 12 I contacts parallel then coupled with acknowledge and reset switches and relay for output to be connected at central annunciator/alarm(this to minimize wiring making all the 36 inputs parallel).
or you can have 12 I parallel to a relay that alarms the main annunciator/alarm system if you dont want a localized per area alarm system.
study ladder diagram, it will make the job even easier.
Good Answers: 120
Re: Alarm Logic
01/21/2012 11:44 PM
Read through a few pages of these links, you can probably find some hints there
Alarm circuitry
Alarm images
Per Ardua Ad Astra
Good Answers: 11
Re: Alarm Logic
01/22/2012 10:56 AM
Like below switch sw1...sw36 parallel with relay R contact, A stands for alarm, ACK stands for a simple switch DPST
Good Answers: 11
Re: Alarm Logic
01/22/2012 11:08 AM
note switches sw1~sw36 should be push button type of switches, not toggle.
Good Answers: 11
Re: Alarm Logic
01/22/2012 11:34 AM
also, missing R relay NO contact in series with ACK(NC) and A.
Good Answers: 38
Re: Alarm Logic
01/23/2012 12:41 AM
Register to Reply 10 comments
aurizon (1); edignan (1); Epke (1); lyn (1); Noudge79 (4); SolarEagle (1); TonyS (1)
