Previous in Forum: Thread Rolling Diameters?   Next in Forum: ANSI Leakage Spec and Calculation
Coal Handling System
01/24/2012 4:56 AM
Dear sir,
I am doing coal handling system erection work.
I want to know the standard sequence of coal handling system erection procedure.
Thanks & Regards
chandrasekaran.n
Pathfinder Tags: Material handling syatem
Re: Coal handling system
01/24/2012 5:16 AM
Er, wouldn't the employer have a standard procedure for this? If not, then what the &$%£ has the Client purchased?
Good Answers: 181
Re: Coal Handling System
01/24/2012 9:18 AM
Start at the bottom and work upwards. Your employer must have work schedule for this work, ask them.
Good Answers: 58
01/24/2012 11:59 AM
Perhaps the design Engineer has specifications or better yet a scope of work, maybe even some construction drawings.
Once you have obtain the required documents you can lay out a sequence of erection.
Follow this path young grasshopper to the destination of coal handling system erection procedure
Register to Reply 3 comments
KJK/USA (1); PWSlack (1); TonyS (1)
