Previous in Forum: Controller Repairs: 860 CFM Atlas Copco Air Compressor   Next in Forum: ABB Control Builder M
10 comments
Flow & Differential Pressure
01/25/2012 5:19 AM
if differential pressure (dp) increase what will be flow increase or decrease ?
Re: flow
01/25/2012 5:28 AM
Across what device?
What is the Mach Number?
Re: flow
01/25/2012 5:37 AM
if i change URV OF TRANSMITTER WHAT WILL BE FLOW INCREASE OR DECREASE ?
Re: flow
01/25/2012 5:40 AM
Please don't SHOUT.
What sort of transmitter?
Please give all the information; this forum is not known for liking games of "20 questions".
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: flow
01/25/2012 5:45 AM
This is a completely different question.
Changing the URV of the transmitter does not affect the flow rate being measured. It merely changes the signal output by the transmitter at that flow rate.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Good Answers: 46
Re: flow
01/25/2012 5:47 AM
This is weird -- the very moment I submitted my last comment, it was rated 5 for "Off-Topic"
Re: flow
01/25/2012 5:58 AM
The response to a posting that is "off topic" in CR4 is automatically "off topic" unless the respondent states otherwise.
Re: flow
01/25/2012 10:30 AM
I hereby break the chain of contagion, by unchecking the OT box to the left below this window.
Good Answers: 46
Re: flow
01/25/2012 5:37 AM
If dp across an orifice increases, it means the flow has increased. However, if you are asking about the dp across some other component in the system (like a pump), it likely means the flow has decreased.
Without a diagram showing the system, it's impossible to know exactly what you are talking about.
Venezuela - Member - New Member
Re: Flow & Differential Pressure
01/25/2012 1:08 PM
Mr technician,
Few weeks ago I asked about Why Δp≈Q² <---- here is your anwser
Regards
JP
Instruments-guy-SAV
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
03/17/2012 8:37 AM
Apply Bernoulli's theory both sides of the orifice.
You will find that flow is directly proportional to the square root of differential pressure.
If you can't find a way, make one........
Register to Reply 10 comments
Instruments-guy-SAV (1); justinanto1987 (1); mr technician (1); PWSlack (3); tonykuphaldt (3); Tornado (1)
