Previous in Forum: 3516B Unbalanced Exhaust Temperature   Next in Forum: Flow Air from Low to High Pressure Tanks
36 comments
Ideas for a Peeling Machine (Manual or Auto) Headless or Whole Prawns/Shrimp
01/30/2012 2:38 AM
I had been working to find some suitable method for peeling warm-water shrimp either automatically or semi-automatically. The conventional machines available on the market are too expensive and lack after sale service and are hard to repair or get parts easily or economically. The automatic ones available on the market (Laitram and Skrmetta) are not suitable for peeling raw shrimp ( though they claim to the contrary) as they turn out too many broken.
The other available (Jonsson) is manually fed but needs periodic cutter replacements, etc, and is hard to maintain in my part of the world (Pakistan). I am thinking about using a rotary broach to see if it is workable without harm to the user or the product itself. Someone told me such gadgets are being used by the Japanese for commercial purposes but I don't know where to get them from??
Any idea I can make my own gadget to boost up production (and quality as well) of hand-peeled shrimp ( sizes ranging from 8/12 to 300/500 pieces per lb)?
Pathfinder Tags: Shrimp peeling machine
Re: Any idea for a peeling machine (manualor auto) headless or whole prawns/shrimp
01/30/2012 2:46 AM
Would squeezing them through rubber-covered rollers work? Do they have to be totally raw, or can you blanch them first? (These are just wild guesses; not sure they would work.)
01/30/2012 3:00 AM
Laitram and Skrmetta USA machines work on the rubber-coated
reciprocating roller principle. I tried this by making a prototype and it
did work but soon I found that it was difficult to maintain fine
clearance between the rollers due to rubber covering slipping or getting twisted
due to roller contact. Unfortunately, it was impossible for me to get
the rollers rubber coated and get them pin-through over here.
Briefly, the conventional roller peeling machines are meant for peeling
pre-cooked shrimp and consist of 38 rollers on a bed of steel.
Any two adjoining oppositely-rotating rollers separated by a thin plastic or aluminum
sheet maintain the clearance between the two, and are reciprocated at
different speeds as a result of which any shrimp entrapped in the slit between
the rollers gets a pinched and as it moves down along the tipped roller
through its entire length it get peeled.
Since absolute precision and special materials are required
to be build these machines, these are not workable in Pakistan where
skilled workers are scant and spares almost unavailable.
Good Answers: 114
02/02/2012 11:11 AM
Re: Ideas for a Peeling Machine (Manual or Auto) Headless or Whole Prawns/Shrimp
01/30/2012 10:18 AM
300/500 pieces per lb?!? those aren't shrimp the're sea monkeys!lol
This machine is good up to 90pp...
http://www.youtube.com/watch?v=vLi_3LYAets
http://www.jonsson.com/
01/30/2012 10:39 AM
You might consider getting your cutting wheels made with harder metal, tungsten carbide...
http://www.prawntomachine.com/
01/30/2012 1:13 PM
01/30/2012 10:16 PM
Thanks a lot. I am trying to assess which kind of broach might be used
for the purpose. A non-technical processor told me that he saw a small
Japanese table-top peeling machine (manual) which consisted of an about
one foot long broach rotating beside a small pin-type roller. The shrimp
to be peeled was manually pushed legs down along the length of the slightly sloping broach and lo! the shrimp was peeled and no hurt was caused to the
fingers too!!
Obviously, this is not a bulk fed machine nor good for smaller shrimp, and has having disadvantages same as other machines
available on the market.
Let's try catch up with some new idea?? Squeezing seems to be
the answer but how??
01/30/2012 10:08 PM
Thanks, I have seen these machines too. The problem with them is
almost the same as previously posted above, ie, labor intensive (each
machine requires one operator), unsuitable for smaller sized shrimp,
excessive wear and tear of cutters, precise adjustments, repair and maintenance, , hand-fed, etc
01/30/2012 10:04 PM
Thanks a lot. I am aware of these machines but they are suitable only
for larger shrimp. Here we manually peel small shrimp, Peeled Undeveined Shrimp (PUD) in sizes
ranging from 100/200 to 400/600 shrimp per lb. Hand peeling is the best
with least broken but the problems with it are delayed processing often posing
risk of semi-decomposition, mixing up of admixture with the meat,
labor intensiveness, etc.
Jonsson machine do well with larger shrimp,
but they are not bulk-fed like the Laitram peelers, hence still somewhat
labor intensive and operationally restrictive on shrimp size.
the world now needs something better, some innovation in this field...
same as some innovation is now desired on refrigeration.
Good Answers: 266
01/31/2012 3:00 PM
At 400/600 shrimp per pound maybe look at aquaculture. Sound like you got a lot of seed stock. Just put some meat on them. Then those big machines will work.
01/31/2012 3:25 PM
for your information there are more than commercially prized shrimp
found in the Indian ocean and the Arabian sea. The smaller size, viz
400/600 is not juvenile shrimp but a fully grown up crustacean. Haven't you
heard of Krills??? How can you put some more flesh on those adults?
..no way
these size shrimp are sold as cooked and peeled and i remember one
US company SauSea foods selling it as ''shrimp cocktail''!! of course these
shrimp also have different uses in culinary regimen...a chef could tell best.
Good Answers: 266
01/31/2012 5:11 PM
Krill may look shrimp like but are not shrimp. Eat a lot of seafood around my neck of the woods never have I seen krill sold.
Good Answers: 130
01/31/2012 6:00 PM
Do not you see stuff like this?
link
02/01/2012 2:11 AM
Yeah, it is this shrimp but of warm-water Penaeid species which unlike
the Pandalus have legs and a bit harder skin to be removed. This type of
shrimp do not grow beyond their small size....nor need be deveined.
They are really delicious and go for making the gourmet's choice!
NB: yet another problem with peeled shrimp is to remove the admixture and
extraneous material that gets mixed with the shrimp meat, any idea how to do
it automatically on large scale, say 100 tons per day????:)
Good Answers: 266
02/01/2012 6:57 AM
No more like this.
02/01/2012 7:34 AM
No, that is headless shrimp, brown and Second grade!! too many black
spots and black tails!! Not good:)
Good Answers: 266
02/01/2012 8:10 AM
These better?
02/01/2012 2:05 AM
Yeah, krill is not shrimp but a favorite food of whales!!
Krill are very minute, just a few millimeters and I have seen them
sold on a supermarket shelf somewhere in Europe.
Cooked and Peeled shrimp are commonly sold. Mind it there is difference
of species between cold water shrimp and warm water shrimp, the multi-legged decapod peneieds.
Good Answers: 102
02/02/2012 8:58 PM
Commercially farmed krill from vast aquaculture operations never make it to the seafood markets.
They are all diverted to baleen whale feed lots for sustainable fuel oil production.
That's why you never see krill being sold.
Think about that the next time you light your lantern.
02/02/2012 10:00 PM
OMG humans snatching away food from whale's mouth!!
No krills will starve the whales and kill them all!
Why not find some better way to light the lantern rather than ruin
the environment??
Canada - Member - New Member
Good Answers: 39
01/31/2012 2:51 PM
Looking for a machine to boost production of hand peeled shrimp?
Anyone else see a problem with that sentance?
All that is required for evil to succeed is for good men to do nothing.
Good Answers: 130
01/31/2012 2:58 PM
Aside from not even wanting to hand feed the machine? What problem?
01/31/2012 3:28 PM
the problem with 'that' is the same as it exists in
your following sentence!!;)
'''Anyone else see a problem with that sentance?''
01/31/2012 3:31 PM
How can you peel, say 100 tons, of small shrimp per day without
a bulk-fed machine???? No joke, I guess!
Good Answers: 130
01/31/2012 4:13 PM
Sorry - just a small in-joke on "hand peeled" as pertaining to import description and truth in advertising. A lot of different people, professions and skill-sets around CR4
But yes, the peeling problem is tricky with these tiny shrimp (Chefs commonly use in Asian mixed rice dishes, soups, puree' and such).
I have thought a bit about the squeezing concept, but haven't commented as I suspect the variation in curl makes it quite complicated. Doesn't present itself as a de-veining solution either - on something about 15 -20 mm (1/2 - 3/4") long and varying in diameter. (assuming this is the product 'that' you are referring to)
But if I think of something actually 'useful', I will be sure to let you know
02/01/2012 2:00 AM
It's all right and thanks for your encouraging words.:)
Bulk-fed Machine peeling machines are made only by Laitram or Skrmetta
but in a developing country where technical hand or back-up service are not easily
available, it makes impossible to use their machines. Moreover, their machines
are basically meant for peeling previously cooked shrimp (although they claim
them to peel raw shrimp as well but this is not truly so from my experience). These companies usually lease out their machines in their countries or elsewhere.
Since long there has been no development in this field and I thought maybe
someone knew a better method to ''pull skin off the little monkeys!!'';)
Well, let's keep trying (like Robert Bruce!).....to reach a solution as there must
be some?
01/31/2012 8:18 PM
Ah yes the euphausiid, now I think we are on the same page....Here is a patent I found specifically for that purpose....
http://www.google.com/patents/US4393544?printsec=drawing#v=onepage&q&f=false
02/01/2012 2:34 AM
Thanks for the search. I think James M. Lapeyre is the same guy who
runs or ran Laitram? Back in 1983 or so I had some communication made
with him regarding a shrimp washing and cleaning machine but things didn't
go further because of my remoteness from his place.
Skimming through his patent, I think excess of gearing will make Lapeyre's
machine unworkable for being run with water all the time and getting corroded
or misaligned! His patent seems to be like a variation of mine (shrimp cleaning machine)which I
developed back in 1983 and sent him an orthographic picture of my patent for his perusal!!
I am still obsessed by the idea of devising a viable gadget for bulk
peeling of shrimp, less intricate and which does not
require heavy repair and maintenance but presently I don't have the
facility to do it!!
Good Answers: 102
02/01/2012 5:06 AM
I was surprised to learn that machines to do this actually existed. Thanks for introducing this to me.
It seems that prawns are mostly hand prepped in most parts. Apparently, humans are well equipped with the basic hardware and firmware and just require a software tweak to get them working.
I often wish I had such a machine while preparing prawns for a meal over my kitchen sink.
Pakistan has very cheap labour right? Do you really want a complex machine in there?
02/01/2012 7:31 AM
Shrimp peeled by hand are regarded as the best shrimp because they
are completely peeled off without bruising or breaking them. However, manual
peeling tends to delay process and partially spoils the product which is acoording to FDA not passable as good for human consumption.
Machines do not match the subtle and nimble manoevering of human hands but are just to augment them for ease and productivity. then all machines cannot be
used independently or specifically to treat all the product phases. For example
all peeled shrimp have to be washed and cleaned off extraneous material such
as antennae , gristles, etc, which again required another machines.
Once I imported a shrimp Cleaning machine from Laitram but it was useless
so I went on experimenting and made my own and got the patent for it in 1983.
I told Laitram about this and others , they were partly interested
but unprepared to enter into an agreement. Clever businessmen they are!
Japanese were also interested but they wanted me to ship them a machine
which i refused as I am not a mass manufacturer.....same happens with people in
other places, such as India. All want to have the machine but are not
ready to take the patent!! You can easily imagine what they are upto??
Problem with machine peelers is that they are complicated and need
perfect alignment to perform which is not possible in a developing counrty
like Pakistan. Labor is surely cheaper in Pakistan but is least
dedicated or skilled, and cannot be trusted. Laws are weak over here
and no sooner you teach someone he will make a copy of your machine
and would be sitting in your competitor's lap!!
Good Answers: 102
02/01/2012 8:35 AM
Training your competitors!!!!!
What a wonderful feeling!
02/01/2012 3:01 PM
Not exactly. It's a matter of confidence gained through long experience
and expertise in the field. Once I told a US shrimp machine maker that one of his
machines was worthless and he ought to improve the design
or stop making tall claims!
Similarly, many years ago marketing staff of a famous refrigeration company(Sabro)
visited my factory and after seeing the installation done by me remarked"
You do not need our services!!
Surely such recognitions give you happy feelings, don't they??
Later I was elected as Associate engineer by ASHRAE!!
Wooohooo!!
Good Answers: 102
02/01/2012 8:50 PM
That's a little different to the scenario you painted in #25.
Nice to hear that your dedication to quality is being recognised and appreciated.
Do you conduct factory/facility tours?
02/02/2012 4:49 AM
A product which doesn't have consistent quality is not salable and soon
loses market.
During my business career I had the chance to inspect various seafood
processing units in the US and Japan. I observed that the Japanese are pretty smart
at handling fish.
No, I don't conduct factory/facility tours as here there are none!
Thanks for your interest..:)
Good Answers: 62
02/05/2012 11:23 PM
I am way out of my field here, but ...
I have seen both compressed air and pressurized water used to everything from medicine injection to stone cutting.
Seems a combination of orientation (rubber wheels) and shaping of the blast should get under the shell and strip it off without damaging the shrimp.
De-veining I think could be done the same way.
12/15/2015 7:05 AM
Dear Sir,
I have been following your thread regarding the Shrimp Peeling Machine and am quite happy to learn that you have been able to procure a patent in the same regard.
Sir, I run a Small Scale industry bssed in Mumbai, India and we have been designing and manufacturing Shrimps/ Fish Processing Machineries. Our detailed profile would be available to you at www.rajmaengg.com or alternatively www.facebook.com/rajmaengg
Sir, I am interetesed to learn more about your know how on Peeling Technology, on an agreement basis and look forward to a honest association with you if everything falls in place.
I shall keenly Await your response on this subject at rajma_engg@hotmail.com
Best Regards,
Kamaal Vijayann
Register to Reply 36 comments
34point5 (3); Apothicus (1); edignan (1); Garthh (1); mazhur (16); ozzb (4); rajmaengg (1); SolarEagle (4); Tornado (1); Wal (4)
