Previous in Forum: Sodium Lamps   Next in Forum: Transformer Test
Good Answers: 19
DC Fan MTTF and RPM
01/30/2012 4:52 AM
Hi, I wonder does anyone have a formula (and its source) for calculating the improvement to be had by reducing the RPM of a DC fan (via PWM for example) some data sheets say "significant" improvements can be achieved but I can't find out how to calculate this.
Re: DC fan MTTF and RPM
01/30/2012 4:55 AM
A reasonable starting assumption might be that the motor's life is so many revolutions. On that basis, life would be inversely proportional to rpm. Then just compute from there.
Good Answers: 19
01/30/2012 5:51 AM
Thanks, if I had to guess I would have said if you halve the speed you double the life, but describing it like this explains that and makes sense. (I realize there will be a rate at which lubricant is lost which would complicate it slightly, but I'm happy with this).
Thanks.
Good Answers: 181
Re: DC Fan MTTF and RPM
01/30/2012 2:56 PM
You have to consider the loss of cooling airflow through the motor at low speeds
02/08/2012 2:49 AM
search "power saving with VFD"
lots and lots of articles on internet on this..
Register to Reply 4 comments
HUX (1); muditmah (1); TonyS (1); Tornado (1)
