Previous in Forum: How to Decide Branch Connection Fittings   Next in Forum: Straigh face /flangeof dishends
Motor Changes
01/31/2012 2:36 AM
Hi there,
I am having a 3 Phase motor 73kw DH1 motor would like to convert the same to a single phase motor. Kindly let me know would it be possible to to use a single phase motor on the exisisting machine which is a garbage food liquidator. What are the possible changes I would have to make like pulley.
Re: Motor Changes
01/31/2012 3:29 AM
It might be possible, but not advisable...You would have to redesign the whole system starting with the power supply...
Re: Motor Changes
01/31/2012 3:57 AM
DH1 = what? How many volts? If rpm stays the same, pulley also stays the same.
Re: Motor Changes
01/31/2012 5:40 AM
Here you go. http://www.electro-tech-online.com/re-projects/100563-3-phase-converter-schematic-miller-system.html
Unless you have a 240 volt 500+ amp power service capable of supporting peak currents of around 1500 - 2000+ amps at startup you wont be able to power it!
Why do you want to go single phase for such a large motor? What do you hope to gain?
SolarEagle (1); tcmtech (1); Tornado (1)
