Previous in Forum: Buying Tungsten Products from China   Next in Forum: Repower Vehicle for Energy Economy, Reducing Noise, Better Safety, Maneuver
What's the Hot Mine Screen?
01/31/2012 10:43 PM
Product Introduce Of Hot Mine Screen:
1.ZSR series hot mine screen is mainly used for grading the sinter of the medium and small size between the temperature 600°C and 800 °C, often used with the metallurgy sintering machine.
2.It uses Quadratic damping system, the vibration load on the base is small, has the special features of sturdy construction, smooth running, low noise, high efficiency.
Work Conditions Of Hot Mine Screen:
1. Both the direction of the moving of materials on the screen and the putting of them should be the same and the feeding gap should be no higher than 500mm so as to reduce the impact on the screen.
2. A heat protection device should be fixed between the vibrating motors and the screen in order to depress the impact of heat on the vibrating motors.
3. Cooling devices should be fixed in order to maintain the temperature on the screen under 500°C
4. Do not fix the hopper, extractor fan and the heat protection device on the main body of the screen and the distance between them should be less than 50mm.
Working Principle Of Hot Mine Screen:
1. Two different forces are generated by two vibrating motors on it and then the screen box starts vibrating. The vibrating motors are fixed on the side shelf so that they do not involved into Vibrating and the screening is successfully made.
2. ZSR hot ore vibrating screen is made up of the screen box, the vibration exciter, the reducing system, the convey device and the base. The beam and the side plate of the screen box are made of heat-resisting and stainless steel.
The Main Features Of Hot Mine Screen:
1.The side plate and the beam of ZSR hot ore vibrating screen are made of high quality and heat -resisting stainless steel and they are connected firmly by ring groove rivet. That's all for the high temperature of those materials under screening.
2. Special equipment is designed to fix the screen plate in order to make it work normally under high temperature. It is characteristic by the firm structure, the stable performance, the low noise and the high efficiency.
Re: What's the Hot Mine Screen?
01/31/2012 11:28 PM
Up Not yours.
02/01/2012 1:22 AM
In Spades!
02/01/2012 1:33 AM
If not no-trumps!
02/01/2012 2:05 AM
OOOuu, you vibrate me long time....
Register to Reply 4 comments
lyn (1); SolarEagle (1); Tornado (2)
