Previous in Forum: Deleting a BOM Item   Next in Forum: Centrifugal Pump Impeller Size
SEC 8 DIV 1 and @
02/01/2012 10:07 AM
Hello all, If this question is redundant on my part, I'm not sure that I sent the first question right so I thought I would try again and re-worded,(since I can't remember how I asked).
Can a 5800 psi vessel be built under Sec 8 Div1 at the expense of size and weight? e.g. thicker walls, heads, nozzels and flanges.
Re: SEC 8 DIV 1 and @
02/01/2012 12:25 PM
What is in the vessel, how much of it and at what temperature?
02/01/2012 3:20 PM
The vessel is a sand seperator and will have a mixture of sand, oil, water and gas. Current spec say5800 MAWP @100 Deg F.Shell is 20" OD with Hemispherical heads.
Thanks
Good Answers: 38
02/02/2012 8:09 AM
TR,
A vessel can be built to the conditions you describe under the rules of the ASME Boiler & Pressure Vessel Code, Section VIII. The special rules for high pressure vessels (>3000 psig) will apply.
I do not understand what you mean by: "at the expense of size and weight"....
Your vessel wall thickness for this diameter and extreme pressure will be approximately 4 inches.
02/02/2012 12:10 PM
"Expense of Size and weight" meaning will Sec 8 Div 1 allow a vessel to be built with bigger and thicker components or will the pressure dictate what division must be used such as div.2 or 3.
Register to Reply 4 comments
MJCronin (1); PWSlack (1); TR (2)
