Previous in Forum: Summation Metering   Next in Forum: Affecting Utility Neutral?
10 comments
Alarm Monitoring System
02/03/2012 11:49 PM
Hi all,
Anybody have idea about alarm monitoring system?
Good Answers: 181
Re: alarm monitoring system
02/04/2012 12:49 AM
Lots of ideas, but based on the information you've give I don't know what would be pertinent.
02/04/2012 11:50 AM
hi mr tonys
actually in our new project we using fire alarm, gas detection,fire suppression,water leakage detection and,gasoline detection systems these all systems all linked with that alarm system that means if any of the above system detect any fault the alarm system wants to produce sound
Good Answers: 102
02/05/2012 3:17 AM
How are you monitoring the alarms now?
02/06/2012 1:27 PM
I am sort of confused...
So, what you have today is "... system detect any fault the alarm system wants to produce sound" So, a local alarm that rings/buzzes/honks/beeps/flashes when any defined alarm condition has been met. This detection and annunciation system is in place and functional today. Is this correct?
So, do you wish for this general alarm signal to be sent somewhere? Where? Via what method? Who will respond? Who is to be advised? Are emergency responders automatically advised? If yes, which discipline?
Are these all defined in the thread and I missed it?
Good Answers: 804
Re: Alarm Monitoring System
02/04/2012 10:52 AM
Alarm monitoing. I personally am an alarm monitor, I listen for my alarm every morning to get me out of bed.
I know they make alarm monitoring systems for the hearing impaired that listen for audible alarms from other things and convert them to visual alarms. They also make the opposite for visually impared people that monitor for visual alarms and convert them to audible.
I also know of several companies that hav e people standing around monitoring alarms who then pick up a phone or radio to tell someone about it. Usually these people are called "Alarm Monitors" but in one local refiery, they call them "Instrumentation Technicians" (no joke).
Good Answers: 19
02/04/2012 10:45 PM
Only two.
I have used ADT: They give good service, but charge for it.
http://www.adt.com/
The Monitoring Center, which I know nothing about, but they're much cheaper.
http://themonitoringcenter.com/home.cfm
If you want some other kind of monitor alarm, for something other than intrusion or fire, you need to specify what you are monitoring, and what the monitor must do, viz. call Police or Fire Dept., send you an e-mail, etc.
02/05/2012 1:15 AM
As someone said it's pointless to respond with at least some info. I was going to suggest a dog.
02/05/2012 7:32 AM
Very funny J , yes there should be more information, and there are all kinds of alarm systems available, you can get them to do just about anything you want them to do these days. Even your cell phone can become an alarm monitoring system.
"We should become the change we want to see in the World"
02/05/2012 7:37 AM
Try Google - "Alarm Monitoring Systems" -
02/06/2012 7:50 AM
Don't use Monotronics they charge a lot and they make you sign a 3 year contract, if you don't read the fine print. They don't tell you that when you are signing! So beware! ADT is not cheap. There are a lot of other companies that charge less for the same service.
Register to Reply 10 comments
abinesh (1); bubbapebi (1); Doorman (1); hernaju1 (1); JEFINE (1); JRaef (1); KeepItSimpleStupid (1); Tom_Consulting (1); TonyS (1); Wal (1)
