Previous in Forum: Take Off Gantry   Next in Forum: Line Following Circuit
9 comments
Load Calculation for Transformer
02/04/2012 2:04 AM
Can some one help me about load calculating i.e i have 24 volt step down transformer for lighting purpose (2.5 kva input 415v output 26v ) the bulb I am using is 60watts 24v now what is formula for load calculating i.e how much bulb i can use on that transformer?
Re: load calculation for transformer
02/04/2012 3:10 AM
How many phases?
I(A) = 1000 × S(kVA) / V(V)
Re: Load Calculation for Transformer
02/04/2012 9:45 AM
If PF = 1.0 (as would be the case for incandescent lights), 2500 ÷ 60 ≈ 41 lamps. If the PF is less, the number of lamps will be correspondingly fewer.
Good Answers: 19
02/05/2012 12:06 AM
True, but...
"To achieve maximum transformer efficiency, maintain average transformer loading between 60% and 80%."
See this item:
http://www.grainger.com/tps/electrical_general_purpose_transformer_selection_guide.pdf
02/05/2012 3:54 AM
That differs from what I have seen elsewhere.
Good Answers: 27
02/05/2012 9:26 AM
Since I did worked for a manufacturer, I remember the allowable maximum load is actually dependent upon on the designer / manufacturer. In my old company the auto-transformer types were designed to safely provide up to a 25% of its rated capacity. The added safety margin are computed for resistive loads, and applicable on transformers having kva ratings of 1 kva and above.
The Isolation type transformers were designed a bit differently due to physical (core and copper) limitations. They were hot tested them to provide 80% of its rated capacity, with 2 degrees C., maximum allowable temperature rise for 24 continuous hours.
In short, real performance mostly will be brand and/or manufacturer dependent plus the country of origin!
vsar
Good Answers: 102
02/05/2012 3:26 AM
What will you be illuminating?
02/05/2012 4:37 AM
Assuming the pf is 1 ( lighting load ):
· 2500 VA can means 2500 watts power . So you can use - 2500 / 60w = 41 lamps as mentioned earlier .
· In another way , the transformer of 2500 VA , can deliver current of : 2500 / 25 ( approx 26 v ) ie., 104.16 amps
· A 60 watts lamp on 24 v , will take - 2.5 amps . So the number of lamps that can be connected to secondary is 104.16 / 2.5 = 41.66 .
Approximately the number of lamps that can be connected is 41 ( Bulbs of 60 w / 24 v each )
02/05/2012 8:09 AM
hey everyone i know all formulas which you are giving
the formulas which the members are suggesting is only applicable if the transformer efficency is 100% then you can say that 41 lamp..... i want to know the average load calculatiion i.e if transformer eff is 80% and pf is 1 then which formula is applicable..
note that transformer connection is Y-Y and line volt is
i/p volts = 415_____420v
o/p volts = 26.5____24v
02/05/2012 9:00 AM
I presume that if you have a 60 watt bulb that you have all ready decided what you are going to put on your transformer, or was the question you were given worded differently?
Register to Reply 9 comments
bubbapebi (1); garth (1); king.faisal (1); SolarEagle (1); Tornado (2); Voltamps (1); vsar (1); Wal (1)
