Previous in Forum: Max Cable Length For Given Voltage   Next in Forum: Can Main Switch Be a Load Break Isolator?
10 comments
Series-Parallel Switch
02/05/2012 11:14 PM
A publisher on the west coast (of USA) tried to describe a series-parallel (Orpin) switch used with 2 batteries to start the vehicle motor with the series voltage while the system (lights, gages, etc) is the parallel voltage. His description was very confusicated!
Can anyone direct me to a website with a good qualitative explanation? I think I myself understand how these things work to provide the starter motor with the higher voltage without the accessories being that voltage. I also understand that these switches are not needed anymore since high torque starters are available.
Thanks.
Lehman57
Re: series-parallel switch
02/05/2012 11:55 PM
This java app is an analog circuit simulator. You build circuits from a wide variety of components or pick (and modify if you desire) any of numerous pre-made circuits (from tesla coils to CMOS NAND).
Instead of a static diagram, you can see how is work, and study the effects of variations made to the circuit.
Analog Circuit Simulator Applet
I hope you find it as useful as I have.
02/06/2012 9:10 AM
Thanks; looks like a good site! Apparently I have to get Java before I can use it, but I didn't see the series-parallel switch listed in the index. How is it labeled?
Lehman57
Re: Series-Parallel Switch
02/06/2012 10:18 AM
I use four batteries in series to get 48 volts for my vehicle while running 12 volt accesories by simply tapping off of the first battery positive post, the second battery positive would yield 24 volts and so on all the way to my 48 volt output on the fourth battery.
02/06/2012 11:30 PM
What do you do to compensate for different current draws for different batteries?
02/07/2012 7:41 AM
Do you use a common ground, or do the separate systems have separate grounds??
02/06/2012 11:21 PM
The trick here is to maintain 14V charging voltage while providing 24V for the starter motor. These switches are common for diesel trucks.
http://www.zafr.com/trucktcom/parallel_sw.htm
The above may explain how they work.
02/06/2012 11:44 PM
Here is one such device that I purchased for my boat - in order to operate a 24V windlass in a 12 V system.
http://www.texasindustrialelectric.com/relays_1119845.asp
Good Answers: 102
02/06/2012 11:49 PM
Sweet!!!!
There's a market for a solution like that here.....
02/07/2012 1:35 AM
good morning sir
I understood ,,you need to operate two systems by two batteries ,,,one need the two batteries in parallel for lights,,,etc,,,,and the other need the two batteries in series for motor,,,,and you need a switch to convert from one to another
excuse me sir,,,you don,t need a switch,,,you need a circuit to fulfill your need to operate the two systems in the same time,,,,is that is your need?
please tell me,,,and I can think with you for solving that problem,,,,
,,,,,thanks,,,,,,,,,ahmed,,,,,,
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 102
02/07/2012 3:56 AM
I've just finished jibbering to one of my mates about this and he informs me that his Toyota Landcruiser has this arrangement as standard. A cold weather heavy duty option apparently.
So, should be able to find the complete relay set in the market ready to connect with little hassle.
Just need to watch where the alternator output wire is connected...direct to battery positive or to the battery cable on the starter solenoid. Not totally blunder proof but not too hard if one is mindful.
Register to Reply 10 comments
ahmed el sonbaty (1); Baffled (2); Biscayne (1); dkwarner (1); Lehman57 (1); truth is not a compromise (1); Wal (2); woodpower (1)
