Previous in Forum: How To Calculate The Surge Current?   Next in Forum: Series-Parallel Switch
10 comments
India - Member - New Member
Max Cable Length For Given Voltage
02/05/2012 12:01 PM
Hi CR4 users I need to know the maximum length that the cable can be laid by considering Voltage drop within range. Voltage=414v 3phase Thanks in advance
key questions why, what & how - just think
Re: Max cable length for given voltage
02/05/2012 12:09 PM
Good Answers: 88
02/05/2012 12:58 PM
Voltage drop is related to current. Without an idea about your current, no estimations possible. S.M.
Re: Max Cable Length For Given Voltage
02/05/2012 4:18 PM
AS SM said you need the amperage to make the calculations. Go here and click on voltage drop. You can enter your information. This is a great site.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
02/05/2012 8:25 PM
I have a novel idea for you....
Check your local installation standards and codes!!
Every country has a set of standards and\or code which you must comply with.
You have not mentioned what the allowable voltage drop is, which the standards will tell you.
You have not mentioned the required or expected current that will be supported by this cable, so even the codes or regulations in your part of the world cant help you.
Some one has directed you to a great site, but be aware, that it may not be suitable for your part of the world, as ambient temperature, mounting method and enclosures and ducting will all impact the final outcome.
Please either get a qualified engineer or technician to work this out for you..
Although this looks like part of a homework question, so you may want to go back to you books too.
Regards,
Sapper
It's all about the Boom! - MythBusters
02/06/2012 1:28 AM
hi sapper, pls tel me where i can get the standard codes in net... pls help me out r send to my mail CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Prabakar
02/06/2012 3:29 PM
sprabakar22,
Check PWSlack's post as it identifies the BS standard that I suspect India uses, the appropriate standards in Australia are AS\NZ 3000 (Wiring Rules) and AS\NZ 3008 (Cable Selection Guide).
If you are not in India, you will have to look up the standards and local codes for your location. They are all slightly different due to local conditions.
What is acceptable in Canada where the temperature is very low, will not be acceptable in India where the temperature is very high.
SAI Global can supply the documentation (at a cost) or other standards companies.
Your local authorities may also have additional requirements beyond the standards and these must be complied with as well.
Do you homework and research what is appropriate to Your area and buy the standards.
Better still get someone who is qualified to do the work for you.
Regards,
Sapper
02/05/2012 9:24 PM
As long as you want it to be, if you can provide big enough cross sectional area of copper.
02/06/2012 1:30 AM
hi parvathaneni, check this link it may useful for u......
http://www.openelectrical.org/wiki/index.php?title=Cable_Sizing_Calculation
Thanks and regards,
prabakar
Prabakar
02/06/2012 3:42 AM
British Standard 7671 again. <sigh>
02/06/2012 3:38 PM
PWSlack,
My dumb question for the day...
Is BS 7671 the standard used in India?
Us colonials down here created our own, just wondering if India had there own or used BS 7671??
Thanks & Regards,
Sapper
Register to Reply 10 comments
eltech (1); Firas Atwan (1); PWSlack (1); Sapper (3); SimpleMind (1); sprabakar22 (2); wareagle (1)
