Previous in Forum: Water Sweating For Airlines   Next in Forum: Welding on C/S Pipe With LTCS Flange
Self Lubricated Sliding Bearings
02/06/2012 2:05 AM
What are differnt types of sliding self liubricated bearings? Where they are used? Advantages? Disadvantages? Load bearing capacity? Where I can get more inforation?
Re: Self lubricated sliding bearings
02/06/2012 2:18 AM
Everything you want to know can be found if you Search GlobalSpec.
02/06/2012 6:12 AM
Using 'google' I found a nice article about hardwood sliding bearing, made by drilling hardwood blocks and boiling then in nut oil to drive out the water and draw in the oil.
ideal for third world counties amd cheapskate cats.
02/06/2012 7:25 AM
HDPE is widely used these days as a sliding bearing for junction baseplates in switch-and-crossing material.
The advantage is the virtual elimination of grease maintenance.
Good Answers: 183
02/06/2012 7:42 AM
Look under "igus".
Good Answers: 130
Re: Self Lubricated Sliding Bearings
02/06/2012 10:28 PM
You might have more luck using the term "linear bearings"
Good Answers: 67
02/07/2012 10:37 PM
Graphite, Cast Iron, PTFE, HDPE etc are considered to be good self lubicated sliding bearings. Garaphite powders act as good lubricant for sliding bearings. Load bearing capacity depend on compressive stength of bearing material and area of sliding contact.
Good Answers: 130
02/08/2012 12:45 AM
Do you guys have Permaglide available there yet?
Just curious
Register to Reply 7 comments
34point5 (2); lyn (1); nick name (1); pritam (1); PWSlack (1); user-deleted-1105 (1)
