Previous in Forum: Temperature Monitoring for Rotating Contacts   Next in Forum: Wires for Inductor Windings
10 comments
Motor Cable Size
02/06/2012 7:19 AM
If i have 5 KW 3 phase motor and 100 meters distance which size cable use please prove with formula
Re: Cable size
02/06/2012 7:39 AM
It does rather depend upon the supply voltage and frequency. Oh, and the method(s) of installation and the ambient temperature too.
Re: Cable size
02/06/2012 10:14 AM
V = 480
Freqvancy = 50 Hz
ambient Temprature = 40-50 C
Impaler motor
Re: Cable size
02/07/2012 3:28 AM
Lovely.
Plug those numbers into the reletive section of the national standard being worked to and "Robert is your mother's brother".
Re: Cable size
02/06/2012 7:54 AM
Dear Sir,
You are taking back us to our engg.college days !! Better refer to any elec data book for search for the answer. This is how you can learn the rope trick ( how to climb without any ladder- I mean any support).
S.Poornam
Anonymous Poster #2
Re: Cable size
02/06/2012 10:22 AM
How did you become so poornam ?
Good Answers: 69
Re: Cable size
02/06/2012 8:44 AM
If you were solving a specific real instalation problem, you wouldn't care about the formula because once done, you'll hardly EVER mess with it; and the command "prove with formula" proves you're cheating on an exam.
Your teacher should inspect every student and hold all cell phones, and in your case, whack your head two or three times.
No Regards this time !
Anonymous Poster #2
Re: Motor Cable Size
02/06/2012 10:14 AM
line current= ((5x1000)/(1.732xp.fxη))
but your problem is distance also included so per phase copper/aluminium = (resistance of it/metre)x100xline current + phase voltage gives source applied voltage.
05/16/2012 12:29 AM
use a 10mm2 armored cable 4core
i want ot helf piple need assistance and to share my knowleged in technical
Register to Reply 10 comments
Anonymous Poster (4); niazi677 (1); Poornam (1); PWSlack (2); toink (1); Yahlasit (1)
