Previous in Forum: Customized Adapter with Ex Brass Gland   Next in Forum: Motor Cable Size
Temperature Monitoring for Rotating Contacts
02/06/2012 6:50 AM
Hi everyone!
I am looking for online temperature monitoring for our sliprings... any suggestions?
Re: Temperature Monitoring for Rotating Contacts
02/06/2012 6:57 AM
02/06/2012 7:02 AM
Go for Masibus Controller 5006H. Simple to use, simple to configure for RTD or Thermocouple.
It comes with a LED display for monitoring purposes; very easily you can get the alarms for your required high or low temperature requirement - only one buzzer will be required.
02/06/2012 7:07 AM
Since it is a rotaning part. RTD can be installed on the brush...or go with laser thermometer.
02/06/2012 7:21 AM
Thanks everyone for the suggestions.... But Im searching for a system to monitor the temperature online...
02/06/2012 7:28 AM
Fine.
How is intended to get the measurement to where it is needed to be?
[Few CR4 postings with only one sentence contain enough information to receive a concise reply, and the respondents are not known for their patience at games of "20 questions".]
India - Member - New Member Popular Science - Cosmology - New Member
02/07/2012 12:53 AM
Good Answers: 61
02/07/2012 1:28 PM
Exergen's industrial division specializes in non-contact temperature monitoring. I have found their products easy to use, accurate and reliable.
Care must be exercised in determining proper placement of the sensor. The contact surface of the slipring has a very low emissivity, and is therefore difficult to measure accurately. I suggest aiming the sensor at the side of the ring, just below the contact surface.
Register to Reply 7 comments
Anonymous Poster (1); BAI (1); bengalayjr86 (1); harjeetsinghengg (2); pwr2thepeople (1); PWSlack (1)
