Previous in Forum: Resistance of 202 and 304   Next in Forum: Gas Sweetening Process
24 comments
Thread/Glue That Will Degrade After a Few Weeks
02/06/2012 9:09 PM
Hi,
Quite a specific question - has anyone got any ideas for a thread material that will be tough enough to last a few weeks, but degrade after around a month outdoors?
The application is as a weak link in radiotag harnesses to fit on small animals. The link needs to be about 10 mm long, similar thickness to cotton, and be able to hold for about 3 weeks while the tag battery lasts, but then degrade enough to break without staying on the animal for many more weeks/months.
Cotton has previously been tried, but this is too durable (doesn't degrade quickly enough). Anything too weak will easily be broken by the animal before the tag battery has died. They bathe daily, so it has to be able to suffer a daily wetting for a few weeks without weakening enough to break during that time.
An alternative idea is to use cotton, but fix the knot in the weak link with a dab of glue that will hold for a few weeks of movement and wetting but then degrade after enough about a month for the knot to give way.
Any ideas?
Re: Thread/glue that will degrade after a few weeks
02/06/2012 9:16 PM
Don't have much time right now: Shape Memory Polymers - Biodegradable Sutures
02/06/2012 9:36 PM
Thanks, but I think surgical sutures break down due to enzymic activity (reaction by the body internally). The harness will be fully external on the animal, and nothing invasive (breaking skin) can be done to them. So it has to be a reaction with the outdoor environment that does the degrading.
Good Answers: 94
02/08/2012 4:16 AM
"Thanks, but I think surgical sutures break down due to enzymic activity"
Could suitable enzymes be applied to the thread when you attach it to the animal?
Good Answers: 29
02/06/2012 9:48 PM
Perhaps the answer is in the application itself. Make the last job of the battery one of severing a fusible link and releasing the harness. This might even be initiated on command. I think I'll look around some and see if this is feasible economically or otherwise. Good luck!
02/06/2012 10:24 PM
Good Idea, a separate battery could be used to hold a small electromagnetic clasp and when the battery dies it releases.
Are these devices being recovered? Are there any worries about environmental hazards from loosing battery powered devices?
Drew K
Re: Thread/Glue That Will Degrade After a Few Weeks
02/06/2012 10:36 PM
You might look for plastics that have poor resistance to ultraviolet light. (Most people are looking for the opposite, and plastics suppliers might not highlight low-resistance types.) Searching on "biodegradable plastics" might find some ideas, though you may have tried this already.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
02/08/2012 4:03 AM
On that, certain supermarket plastic bags (Tesco) biodegrade over time. I'm not sure of the time scale, or if it's UV dependent. They do degrade in the dark...certainly in the space of months. I've not studied/measured the time needed, I've just stored things in bags, gone back to retrieve them and had the bag disintegrate when I touch it.
Not sure where the OP is, but if he's really desperate, I could mail him some bags....
Chaos always wins because it's better organised.
Good Answers: 75
02/08/2012 7:18 AM
Just in case....
This was meant as a serious suggestion. The plastic bags, cut into strips would be strong enough to act as the links to hold the tags onto the animal's neck (I assume), whilst degrading and breaking the collar after a time.
I was not suggesting tying whole plastic bags round the animals!
I don't know how long the bags take to break down - more than 4 weeks, less than a year is my guess based on unobservant observations (e.g. when I pulled out a bag to use last night and it deposited plastic confetti on my floor) Tesco's website (www.tesco.com) may have some info in their environmentally aware propaganda.
The OP doesn't show his country of origin, so in case he's not in the UK, and as I know Tesco have withdrawn from the US and I don't believe they have a presence elsewhere, my offer to post/mail some is genuine.
OP: PM me if you want some!
Alternatively, I believe starch-based plastics are widely available. These are compostable, so must break down. Again, you'd need to do some research into timescales.
Good Answers: 130
02/08/2012 2:43 PM
GA
Those bags (and others rated bio) are primarily UV degrading but also do in land fill.
As a general comment to the OP: My inclination would use UV properties - rather than soluble or enzyme materials given Baths and possibly rain, even saliva, are involved.
02/06/2012 10:48 PM
You might incorporate a micro electromagnet for holding the device in place, as the battery weakens so does the hold...or they have some with permanent magnet that is then neutralized with signal...
http://www.alibaba.com/product-gs/317344005/ZHI_0222_Micro_DC_AC_Electromagnet.html
02/07/2012 12:00 AM
Maybe check out adhesives formulated with polyvinyl alcohol.
Polyvinyl alcohol - Wikipedia, the free encyclopedia
I used this years ago as a scuttle plug to sink sonobouys deployed on the ocean.
You'll need to talk to current day suppliers, but..................
02/07/2012 6:17 AM
Thanks for replies so far.
Re a release mechanism on the battery - this is used on larger tags but isn't possible on mine, as the tags are already pared down to the absolute minimum weight (0.4 g) to be able to be used on the small animals. They are also already manufactured and potted in epoxy by the supplier.
The tags can't gain any more weight or be changed, so the release has to be in the harness.
02/07/2012 6:48 AM
What type of animals?
Would it be possible to glue the tag directly to the animal's skin or in it's hair?
There is a suture material that's made for internal stitching, that stays wet but degrades over time.
Looks like lyn already touched on it. These people say they can adjust the time of degradation.
http://polynovo.com/innovations/
Good Answers: 74
02/07/2012 10:46 PM
The Twain Has Met
02/07/2012 8:57 AM
02/07/2012 3:55 PM
If suture material is unsuitable, then why hot directly use "superglue" onto bare skin?
One of the development reasons for "superglue" was for field dressings and is often used in hospital s now instead of suturing. If applied to the skin, it will fall off when the next layer of skin exfoliates. (Just like it does when used on people.)
Fancy that, experimenting on humans for chemicals to be used on animals!!!!
02/08/2012 8:02 AM
Gluing to fur/feathers/skin is an option, but they can often very easily pull the tag off, and damage themselves while doing it. Supergluing direct to the body is also considered a bit invasive/unethical (these things are overseen by the Home Office - it's pretty tightly regulated).
I'm limited to making a harness (out of 2-3 mm elastic cord), which has to have a degradable weak link, and have to be extremely light - the tag weighs 0.4 g and i can't get much above 0.5 g for the complete tag/harness set-up. Even superglued knots have to be sanded down to shave ff some weight.
The papier mache suggestion might have some legs, as a small join between two parts.
Location: OZ, otherwise known as Oklahoma were the wind comes sweeping down the plains.
02/08/2012 10:50 AM
Maybe Instead of a knot, just overlap the loose ends with a spot of glue. The more overlap, maybe the longer the time to degrade.
02/07/2012 10:26 PM
Suture glue. I am pretty sure it is basicly just super-glue anyway (as others have recomended already). A quick google and I found this:
Glue
  • Keep the wound dry.Your child may have a shower or a brief bath after 24 hours but do not soak or scrub the wound until fully healed. Pat the wound dry with a towel after giving your child a shower or bath. Do not let your child go swimming or have a soak in the bath for 5 days.
  • Do not let your child rub, scratch or pick at the glue or the wound. If adhesive tape (such as Steri-Strips) has been applied over the glue allow it to fall off naturally- do not pick it off as this may cause the wound to open. The glue may take up to three weeks to completely fall off your child's wound.
  • Do not use creams or ointments over the glue or near the Steri-strips. This may cause the glue to soften and come off.
  • The glue is see through so you can see the wound.
Swap the word "child" with "animal". Happy hunting/tracking.
P.S. "dermabond" is a brand name that popped up.
Fish dont know they're underwater.......think.
Safety - Hazmat - R&D Engineer/Inventor
02/08/2012 7:41 AM
How about making the harness/tag from Papier-mâché. It is made from flour, salt, water and paper. You make it water proof with a silicone spray or a waterproof paint. It can be made to be very strong by adding layers and when dry it is very light and strong. It will break down easily outside after a short while, the time which could be controlled by the water proofing material. The animal or his friends may even eat it off.
masterblaster
02/08/2012 2:46 PM
I'm thinking along these lines myself. I was thinking of simply using a flour paste to bond the ends of a threaded loop. The problem would be drying it quickly to set it. Maybe using ir?
Good Answers: 102
02/08/2012 10:03 AM
Natural latex elastic rubber bands will perish with time.
In the tropics any where from a week to a month and they are finished.
02/08/2012 11:45 AM
At the risk of sounding like a broken record, from the link I cited earlier:
"However these properties are dependent on humidity, in other words, with higher humidity more water is absorbed. The water, which acts as a plasticiser, will then reduce its tensile strength, but increase its elongation and tear strength. PVA is fully degradable and dissolves quickly."
I'll be quiet now.
02/08/2012 12:16 PM
You could always eliminate the weak link altogether, or is this too expensive.
The size of a grain of rice and implanted under the skin.
http://www.corerfid.com/solutions/IndustrySolutions/IndustryAnimals.aspx
Register to Reply 24 comments
34point5 (1); Anonymous Poster (1); claritysable (1); Drew K (1); English Rose (2); Grand Poobah (1); Just an Engineer (1); kramarat (2); ky (1); lyn (3); masterblaster (1); Nigh (1); RDGRNR (1); richardhbeverley (3); snatr (1); SolarEagle (1); Tornado (1); Wal (1)
