Previous in Forum: Transformer Details   Next in Forum: How to Change Varying Voltage From 400-100 Vdc to a Constant 12 or 48 Vdc
Generator Clearance Issue
02/10/2012 4:24 AM
If Lower quide bearing of Generator (High Voltage Generator) clearence is not proper ,Is there any affect in Electrical System of Generator( especially Winding Stator/Rotar)??????If YES What is recommand Internation Standard Specifications for air gape clearence between rotor pole and stator for Large Generator???
NB:May someone give me chart (ISO AIR GAPE {STATOR WINDING TO ROTOR POLES GAPE} CHART BASED ON RATING OF DIFFERENT MACHINES)???
ISO:::Internation Standard Organization
ADDITION:India Standard Specification,Sweden, Swis (ABB),UK,USA...ect maybe acceptable if any.
Re: GENERATOR CLEARENCE ISSUE
02/10/2012 4:29 AM
What does the original equipment manufacturer's local technical specialist have to say on the subject?
02/10/2012 4:38 AM
Until the rotor begins to contact the stator (whereupon all hell will break loose), there is likely to be little or no effect on the generator's electrical performance. Just think about it.
02/13/2012 1:45 PM
That is a GA. The closer the better until you get an eccentric rotor then you're done.
I have seen rotor bars slung out and you may not know it's open without special equipment and base line of it when healthy. The gap is factory designed of the material makeup, size, speed etc. of the device.
It's not Rocket Science
Good Answers: 266
Re: Generator Clearance Issue
02/10/2012 8:43 AM
What do you mean by Lower grade bearing? If you are talking specs as changes in rating like ABEC. There would be little change in rotor to stator clearance to make a difference. Changes in these rating effect eccentricity. There would not be enough change in eccentricity to cause appreciable change in generator output. Unless in lowering the grade of bearing you have exceed it's rpm rating.
ozzb (1); PWSlack (1); Rockyscience (1); Tornado (1)
