Previous in Forum: The Right Answer to the Wrong Question?   Next in Forum: Ground Engaging Equipment
9 comments
Biomass Power Plant
02/11/2012 11:25 PM
Is there a small (1-5 MW) biomass power plant anyone knows of?
Re: Biomass Power Plant
02/12/2012 12:53 AM
Look up biomass power plants from this list of power plants.
Regards JD.
02/13/2012 1:09 AM
This 1 - 5 MW wood chip plant is located in Roddickton Canada, if you contact them they maybe able to help, Roddickton can also be Googled, plenty of information about the above there.
Regards JD.
Good Answers: 19
02/12/2012 1:34 PM
yes contact at duconems at the rate yahoo dot com. Am a gasification consultant too.
02/12/2012 4:00 PM
Good Answers: 19
02/12/2012 11:27 PM
Thats not a biomass gasification but a biomass/solid fuel/coal CFB Boiler with Steam Turbine.
Good Answers: 19
02/12/2012 11:54 PM
Sorry, I take back. He is asking Plant and not specified gasifier plant. So you are 100% right with a Boiler + Steam Turbine. The 2nd Option is Biomass Gasifier + Gas Engines. Am dealing in both system as alternate fuel here in Pakistan because we ran out off gas.
02/13/2012 12:07 AM
Hey guys, thanks for the great posts! I live in Alaska and have a wood pellet mill which makes pellets for pellet stoves. I am interested in producing power with my pellets in a biomass type boiler. I have not been able to find a company that can meet my small needs, 1-5 MW. Does anyone have any suggestions on small biomass systems that I could purchase? Does anyone have any sugestios on how to build my own boiler and generator? Thanks, Chris Elder
Good Answers: 19
02/13/2012 12:16 AM
Any Project like this will cost you $2000~$2200/Kw. Do you have that much money? I have biomass/wood pellet Burners . You then need a superheated high pressure steam boiler + steam turbine. Check Videos:
http://v.youku.com/v_show/id_X MjkzNDE3NTIw.html
http://v.youku.com/v_show/id_X MzAzNDIzNTg4.html
02/13/2012 3:31 AM
Yep. 20-odd of them being installed in Scotland, fired on forestry waste.
Register to Reply 9 comments
chriselder (1); ducon (4); jdretired (2); PWSlack (1); SolarEagle (1)
