Previous in Forum: Diode   Next in Forum: Selecting Generator Capacity
Wind Turbine Transformers
02/13/2012 11:30 PM
What are the necessary specifications for dry type transformer if it is being installed inside the nacelle of wind turbine?
Is Dry type the best option for this installation i.e. inside nacelle?
Thanks and Regards,
Vinod
Pathfinder Tags: transformers
Re: Wind turbine transformers
02/14/2012 12:07 AM
Good Answers: 58
Re: Wind Turbine Transformers
02/14/2012 8:52 AM
Were you not supplied with the technical specifications by the wind turbine manufacturer or is this a homework question?
If you are going to install a wind turbine, contact the manufacturer and obtain the technical specifications.
02/14/2012 11:23 PM
Solar Eagle has provided a valuable info.If the dry cast transformer placed inside nacelle, Cooler fan's are installed.
Main reason to choose dry type is to avoid oil related problems.
Temperature rise of transformer to be monitored continuously (Make sure that it doesn't reach igniting temp of FRP Material) particularly during full generation period.
Above these are my personal experiences,Above things changes from one windmill manufacture to another.
Good Answers: 102
02/14/2012 11:52 PM
The specifications should be selected to prevent this from happening...
Apparently they are hard to extinguish.
02/15/2012 1:46 AM
Thanks for above replys
Are the Slim type transformers more effective than Dry type transformer for nacelle installation?
Thanks and regards,
Vinod
Good Answers: 102
02/15/2012 2:03 AM
What do you mean by "more effective" Vinod?
Form follows function.
In addition to correct function, there is, size, weight, efficiency, safety, reliability, serviceability, operating environment paint colour and a host of other attributes that only the designer (you?) and the turbine's nacelle can consider. And then if it is only available in one form for the electrical characteristics required you have to determine how to negate any undesirable attributes that a compromise may stimulate.
What is your objective and what are your concerns?
02/15/2012 2:30 AM
By "more effective" i meant in fire risk between dry and slim type transformers.
my ojective is selecting dry type or slim type transformer for nacelle installations.
i am concerned with size, fire, vibration and noise level effects of the transformers for both types
Register to Reply 7 comments
KJK/USA (1); SolarEagle (1); sriram1988 (1); vinodk (2); Wal (2)
