Previous in Forum: Carrier Shift   Next in Forum: Field Bus Cable
Where to Use Current-to-Voltage Converter
02/15/2012 7:34 AM
I understand the principle of operation of a Current-to-Voltage converter but where in the Plant do you use it? On which process? What will you be measuring?
LUCK: A prepared man meets opportunity
Re: Where to use Current-to-Voltage converter
02/15/2012 7:49 AM
Anywhere where a current signal is to be converted to a voltage signal.
"Simplesζ!"
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: Where to Use Current-to-Voltage Converter
02/16/2012 1:27 AM
Say you have a sensor that gives isolated current output etc and you have a controller that accepts only voltage input you may use the same.
for more updates visit
http://en.wikipedia.org/wiki/Current-to-voltage_converter
Register to Reply 2 comments
