Previous in Forum: Where to Use Current-to-Voltage Converter   Next in Forum: Control Valve
Field Bus Cable
02/17/2012 3:04 AM
Hi all,
Please give me the solution for,
1. What is the maximum lenth of Field bus cable will be used to instruments from the local junction box?
2. Any alternate if exceeds the said length?
3. If there is the maximum length limitations what is the reason ?
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: Field Bus Cable
02/17/2012 4:04 AM
maximum length : Foundation field bus 9500M with 4 repeaters,
NO
YES. Signal strength and power to reach field divice.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Field Bus Cable
02/17/2012 7:07 AM
Please explain your length units. "M" is the pre-fix for "Mega" meaning 106.
Surely the maximum length is the same as that of a piece of string?
Are the figures given for copper wire or fibre optics?
Chaos always wins because it's better organised.
Re: Field Bus Cable
02/19/2012 11:19 PM
Hello English
You may go through this for more info,
http://en.wikipedia.org/wiki/Foundation_Fieldbus_H1
Regards
Naveen Menon
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Field Bus Cable
02/17/2012 3:46 PM
Based on your questions, it looks like you haven't seen the Fieldbus FOUNDATION's documents yet. Take some time to study these:
http://www.fieldbus.org/index.php?option=com_content&task=view&id=150&Itemid=326
Their System Engineering Guidelines document is especially important to read.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
English Rose (1); naveen_menon (2); tonykuphaldt (1)
