Previous in Forum: Pump for Vertical Beach Well   Next in Forum: Pneumatic Test
10 comments
Which Pipe Schedule to Use
02/16/2012 11:57 PM
Hi
I have calculated the thickness of one pipe and it comes out to be t=0.203in with NPS 6 pipe . Now i want to find schedule no. of this pipe from ASME B36.10 standard (page attached) . Infront of schedule No . column i find three dots (...), whats the meaning of that . and which schedule no. I would use.
Kindly help
Re: Which Pipe schedule to use
02/17/2012 12:25 AM
Not available? I would go with schd 40...
http://en.wikipedia.org/wiki/Nominal_Pipe_Size
02/17/2012 1:48 AM
Can you explain a bit why would you go for Sch 40 pipe..?
02/17/2012 9:06 AM
With a wall thickness of .280 it is the next available option....without going to more expensive custom order...
Good Answers: 34
02/17/2012 2:04 AM
.203 = 5mm.
Sch Std: 7.11, then use Standard
02/17/2012 2:23 AM
Use the schedule that has a wall thickness ≥ the calculated requirement.
Good Answers: 61
02/17/2012 6:09 AM
There is another possible answer to the "three dots"
http://www.pipingdesigners.com/downloads/pipechart.htm#choice
This version of the pipe wall thickness chart has blank boxes instead of the three dots. However it does have the same wide range of wall thicknesses listed. So this suggests that it IS available.
I think the three dots (or the blank) actually means that there are special wall thicknesses available but do not "fit" into the generally accepted classifications of schedule numbers (40, 60, 80, 129, etc) or the "Std, XH or XXh" designations. These other three dot wall thicknesses may be available from some pipe suppliers but may also be much more expensive.
If .203 wall is available but is more expensive you may want to move up to the more common but less expensive sch 40.
Only your local pipe supplier can answer this question.
Do it once and do it right
Re: Which Pipe Schedule to Use
02/18/2012 1:14 AM
• Use the next greater commercial pipe wall thickness found from Table 2 of ASME B36.10M "Dimensions and Weights Of Welded And Seamless Wrought Steel Pipe" to be 0.280 inch which corresponds to 6" NPS, Sch. 40 (or STD).
• For more details, see the solved example at my post #1 of CR4 Thread: Schedule of pipe.
Good Answers: 203
02/18/2012 1:48 PM
In the "Down and dirty" world of practical Chem Engineering and Pipefitting the common practice is: If the specified pipe schedule is not available, too costly, too long a delivery, too expensive, etc., go with the next thicker wall schedule. This is a conservative approach to the problem by going in the pessimistic direction with its better properties and not taking the chances involved with a thinner wall thickness. This approach has worked for hundreds of years and reduces the risk of an unplanned and perhaps harmful event.
As an aside, many times a thicker wall schedule such as 80 vs. 40 is used to extend the time between anticipated repair or failure events simply because there is more wall to be erroded before failure. This is especially true in steam and steam condensate service, a particularly harsh application. The cost of the next set of replacement parts of the thinner materials, the labor cost and especially the cost of process equipment down-time is much greater than the cost of using the more expensive thcker wall (higher schedule) materials initially.
Good Luck, Old Salt
Good Answers: 38
02/18/2012 4:04 PM
Good answer "Old salt"....
Most piping systems in use are schedule 40 ( or Standard wall)
Student, what are you going to do about flange and valve ratings ???? ?
What is your design temperature and pressure for the system and why do you not have piping specifications ?
02/20/2012 1:56 AM
Don't you need to add corrosion alowance to your calculated thickness before looking for the standard schedule no.?
After adding corrosion alowance, take the schedule number of the nearest next thickness from the sch. table.
(...) these dots means those thicknesses are also coverd under the standard but are not available commercially. To reduce the commercial inventary, standard schedule number pipes are manufactured and used in industry with sufficient margine of safety.
Register to Reply 10 comments
Abdel Halim Galala (1); MJCronin (1); Mukesh0861 (1); old salt (1); PennPiper (1); SolarEagle (2); student_11 (1); Tornado (1); Whitephone (1)
