Previous in Forum: Insulation Class F/B   Next in Forum: Do You Know This Part?
One-Line Diagram for PV System
02/20/2012 5:25 PM
Hi guys,
I am new to this forum and I really need your help. Can anyone help me find a one-line diagram of a distribution system containing a grid-tied pv system (a case study)? I am trying to formulate transfer function of the system for a control methodology to regulate voltage at the point of common coupling. I can easily find out the transfer function if I had all the values. It should have all the parameters like source voltage, transmission line impedances, transformer(s) rating and impedances, load impedance, PV system capacity and so on. I spent weeks looking for it online and unable to find one. The parameters should be real values on some kind of project (a case study). Any help is appreciated.
Re: one-line diagram for PV system
02/20/2012 5:38 PM
You might find what you want here...or here...
Good Answers: 44
Re: One-Line Diagram for PV System
02/22/2012 3:24 PM
I'll work out some rough numbers...but I think this is pretty close to a complete one line...
(may as well break the students in early...)
02/22/2012 6:33 PM
What I needed was an impedance diagram (one-line diagram) of a distribution system with a PV system as one of the distributed generations. I need some kind of case study has shows all of its parameters like impedances, voltage levels, peak load, PV capacity etc. Thanks anyway.
Good Answers: 102
02/22/2012 9:52 PM
What is the intended purpose of this case study once completed?
02/22/2012 10:47 PM
What I am trying to accomplish is the voltage regulation at PCC. PV inverter would inject / absorb reactive power so that the voltage is at the nominal level. For this, I need a case study of a distribution system with PV system as one of the DGs so that I can simulate my results. It is a control methodology and I am gonna need distribution system parameters. In short, I will need to formulate a transfer function for my PV system. I will need one-line diagram (showing all impedances). Let me know if it is still confusing.
cuba_pete (1); saryal911 (2); SolarEagle (1); Wal (1)
