Previous in Forum: Designing at Very Low Temperature   Next in Forum: Tesla Bifilar Inductor
13 comments
Cell Phone Charger - Life Expectancy
02/24/2012 10:46 AM
Re: plug in battery / cell phone chargers... Does the life expediency of a charger diminish if left plugged in after a battery / device is sufficiently charged? I have been told the powering up / down of the charger (unplugging and replugging) significantly reduces its life.
Re: LFett
02/24/2012 11:00 AM
My opinion is, it doesn't matter. There's not much to fail in modern chargers and the phone will probably be obsolete long before the charger dies.
I've had my current phone for 5 years and leave the charger plugged in all the time.
I plug my phone into the charger every night, with phone still on, and leave it on there until the next morning when I unplug and go.
Re: LFett
02/25/2012 8:30 AM
Have mine plugged in for over 5 years. No problems.
oilcan13
Good Answers: 18
Re: Cell Phone Charger - Life Expectancy
02/24/2012 2:40 PM
I sincerely doubt that you will find any definitive test data to support the theory that a charger's life expectancy will change due to unplugging it.
The only life expectancy of an electronic device that you are likely to get from a manufacturer is the duration of the warranty. Some electronic devices will fail about a month after the warranty expires while others will pretty much last forever regardless of whether they are used once a month or ten times a day.
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
Good Answers: 804
02/24/2012 6:26 PM
My basic rule is that with electronics, heat x time = failure. The unknown in this situation is the extra heat created by transformer inrush when you power it up. In other words yes, leaving it powered up, even unused, is still creating some very mild thermal stress due to low amounts of ciurrent over a long time, but how that compares to the thermal stress created from extremely high amounts of current for very short times is unknowable. Probably a wash. If anything, MAYBE leaving it plugged in will hurt more, but you have to put it in perspective: it might last only 22 years instead of 25. Are you going to notice the difference? No.
The point about the cell phone going obsolete first is 100% true. I have NEVER seen a "wall wart" die before the phone it is used for ceases to function in whatever changing network environment exists with a carrier, and whenever I change carriers they have ALWAYS told me that whatever phone I currently have will no longer be supported. I used to keep the wall warts, just in case, I fionally gave up because I had a dozen or so, just taking up space.
02/24/2012 10:45 PM
Unplugging and re-plugging greatly impacts the lifetime of the charging connector. That is the weak spot.
The care and feeding of the battery depends on the battery chemistry and how well the charger is designed. A Lithium charger HAS to be designed somewhat, otherwise the battery may explode while a NiCad or lead acid charger can be designed poorly and cheaply.
02/25/2012 9:15 AM
If all the chargers and TVs on standby were all switched off completely, we would need a great many less generating stations around the world.
Leaving it plugged in (or a TV on standby) opens up the possibility of it going wrong and starting a fire.
Check your insurance premium to see if you are still covered with full fire insurance in such cases. Fit smoke detectors.
02/25/2012 10:31 AM
The questions are:
1. Does the life expediency of a charger diminish if left plugged in after a battery / device is sufficiently charged?
Correctly answered already in many replies:
"No bad effect" in genral.
In my view it is not recommended in under developed countries and areas where power interuptions are frequent.
2. I have been told the powering up / down of the charger (unplugging and replugging) significantly reduces its life.
By plugging in and out may have different effects like:
a. It is an intruption and life of all the electrical components/ gadgets have life in limited number of operations [no matter in thousands operation].
It is my experience in PCs and other Gadgets that failure is mostly on switching off or on.
Any how most of the charger/ adopters failures I have come across are due to wires broken at the entry point of output plug which due to sharp bends given to by users.
Good Answers: 110
02/25/2012 2:56 PM
Most "wall warts" these days are switch mode, meaning they do not have transformers and therefore have very little inrush current (and very little idle current when plugged in but not charging). Most are not detectably warmer than room temperature when not charging, indicating they are drawing very little current.
In areas where power is unreliable, with lots of spikes, perhaps these devices are more likely to be harmed from leaving them plugged in. But otherwise they tend to last longer than the thing being charged, regardless of whether you leave them plugged in or not.
You can have fun going around your house with a power meter to see what things draw significant amounts of current.
Think big. Drive small.
02/25/2012 5:10 PM
In my opinion in would decrease their lifetime. That's because it is energizing and de-energigizing the transformer coils. In other words heating and cooling them.
Did you ever notice how incandesant light bulbs rarely seem to burn out when left on, it always seems to be when turning them on again.
02/26/2012 8:39 AM
As already posted, modern small chargers have no mains transformer as they are SMPSs. No inrush current.
Also often as high as 90% efficient....
Good Answers: 102
02/25/2012 11:37 PM
Thermal cycling (on/off) can accelerate mechanical failure. Prolonged high temperatures can accelerate component degradation.
The wall warts don't get hot when they are on standby, as someone else said they barely get above ambient.
They last longer if you leave them plugged in for daily use and if you use a wall wart once a month it will last longer if you plug it in only as required.
Hardly worth worrying about.
Others here have mentioned their collection of wall warts that have outlived their portable appliances. You figure that these would have been standardised by now for reuse instead of including a new one with every portable appliance purchase.
I'm waiting for a retailer to ask me, "Would you like a new wall wart with that or is your old one still fine"? Less packaging, lower freight costs, jingle in MY pocket.
02/26/2012 3:09 PM
Incandescent lamps fail for another reason. Their cold resistance is about 10-15x less than the hot resistance.
A cell phone USB charger would charge at 100 mA at 5V or 0.5 W. At 1 AMP 5 Watts and at iPad levels, a little over 2 amps. The flexing of the cables and the charging connector itself are the weak points.
Location: OZ, otherwise known as Oklahoma were the wind comes sweeping down the plains.
02/28/2012 10:38 AM
You may be waiting a long time for that retailer's question, it has been my experience that every time I replace my device, it requires a different charger plug.
Register to Reply 13 comments
Andy Germany (2); EElectrician (1); Grand Poobah (1); Haajee (1); JRaef (1); K_Fry (1); KeepItSimpleStupid (2); lyn (1); oilcan13 (1); snatr (1); Wal (1)
