Previous in Forum: Missing Characters From a Commodore 64 Character Set   Next in Forum: Medical Instruments Tracking Software
File Expiration
02/25/2012 9:42 PM
Hi All,
using the date function in excel or word, is there a way to set an expiration date for a file so that after certain date the file become inactive.
Regard
kumaran
Re: file expiration
02/25/2012 9:46 PM
There might be a way to use macros to switch a file to read-only after a certain date (or maybe even to delete it). Why do you keep flogging this issue?
Anonymous Poster #2
Re: file expiration
02/25/2012 10:43 PM
Yeah. Put a sticky note on your calendar saying "Delete file xxx on (Month)/(Day)/(Year)."
Re: file expiration
02/25/2012 10:48 PM
Good Answers: 59
Re: File Expiration
02/26/2012 8:11 AM
I've heard that certain programs, like SharePoint, can do this.
I'd just sort my folder ascending by date, check for what's old, and delete it.
Re: File Expiration
02/26/2012 11:02 PM
It depends on what you mean by inactive. Please define.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: File Expiration
02/27/2012 3:55 AM
Third time lucky??
Chaos always wins because it's better organised.
Re: File Expiration
02/27/2012 8:39 AM
Hello,
The code below will prevent an Excel workbook from being opened beyond the date you choose (change 2/27/2012 to the date of your choice).
CAUTION - This is just a starting point, you will need to figure out a way to re-open the file beyond the date as it will lock you out as well - maybe a version without the code. Also, what you put in the "THEN" block may include code to inactivate any active content (controls e.t.c.) in your file.
Cheers.
Private Sub Workbook_Open()
If Now > CDate(#2/27/2012#) Then
MsgBox "File has expired and will now be closed"
ActiveWorkbook.Close savechanges:=False
Else
End If
End Sub
Reply Good Answer (Score 5)
Anonymous Poster (1); English Rose (1); SavvyExacta (1); seg (1); SolarEagle (1); Tornado (1); wsjackman (1)
