I have a client with a small, seasonal micro-hydro potential. The main goal is to heat the water for a radiant floor system directly from the hydro. I have done the standard searches and have not found a solution. The micro-hydro may put out, at most, 500 watts (48-150 VDC depending on the final setup). The hydronic heating system would have a 32 gallon H2O heater inside and, say, another 10-15 gallons in the radiant tubes. The system would be closed loop and in an insulated slab. Given the local climate, the slab and water would radiate at about 55-60°F. What kind of temperature rise over time could I expect with this input?
