hello,
We are installing oil (HFO) fired boiler of 10 TPH , 12 kg/cm2 working pressure .
We have tank farm area where we are storing furnace oil and also have a day tank near boiler. Main storage is 500 meter far from day tank.
Now Furnce oil piping is to be laid down with electric tracing line.Fuel supply will be pumped from main storage tank to day tank at a pressure of 7 kg/cm2 & temperature 90 DEg C approx.
My question is that which pipe should we use for laying between main storage & day tank , Should it be SEAMLESS OR ERW (Gr B Is 1239).
I have read the ASME B 31.1 but it is not mentioned specifically about pipeline for furnace oil.
Also i want to know which standard should I follow for above pipeline.
