Previous in Forum: HVAC Reheat   Next in Forum: Vapor Accumulation in Pump Recycle Line
How to Avoid Cracks In Stainless Steel FCAW Welding?
03/12/2012 2:21 PM
hai all,
We have done the Flux Core Arc Welding in stainless steel Gr.321 with E347T0-1 wire, center line crack has occurred on the surface of the welding. What is the root cause of this crack, how can we avoid this?
Re: How to Avoid Cracks In Stainless Steel FCAW Welding?
03/13/2012 12:47 AM
It because of too fast of cooling rate made too high residue strain energy.
Preheat the work-piece at 250-300 degree C may help together with heat the welding line immediately after welded to reduce strain energy can protect from crack.
03/13/2012 2:26 AM
Pre heat should be at ambient temperature.Very important your maximum interpass temperature is 175 deg C.Slow Cool under insulated blanket.
GOD's surname is not dammit!!!!!!!! He who looks down on others will not be looked up to.
Good Answers: 34
03/13/2012 2:36 AM
Thickness?
Good Answers: 67
03/13/2012 3:32 AM
Did you follow WPS?
Register to Reply 4 comments
chyagon (1); Jerry Mesthrie (1); pritam (1); Whitephone (1)
