Previous in Forum: How to Avoid Cracks In Stainless Steel FCAW Welding?   Next in Forum: Compressor
Vapor Accumulation in Pump Recycle Line
03/12/2012 3:09 PM
we are facing vapor accumulation problem in recycle line of our single stage motor driven centrifugal pump on lube oil service.When pump is tested on recycle by keeping its discharge valve closed,time delay in achieving its desire pressure is observed due to vapor accumulation in the line.Flow through recycle line is controlled through an orifice of diameter 5mm.
  1. what should be done in order to prevent vapor accumulation in the line?
  2. What will happen if we go for increasing the size of flow orifice in the recycle line?
  3. What will happen to pump performance if we go for decreasing the size of recycle line?
aleeehsan@gmail.com
Re: Vapor Accumulation in Pump Recycle Line
03/12/2012 10:05 PM
Hi Ali,
You said: When pump is tested on recycle by keeping its discharge valve closed,time delay in achieving its desire pressure is observed due to vapor accumulation in the line.
  1. What kind of vapor are you talking about? You failed to specify.
  2. What is the temperature of the lube oil?
  3. What is the inlet pressure? Does this differ from normal?
  4. What is the outlet pressure? Does this differ from normal?
  5. If it is water vapor, how is it getting in the oil to begin with?
  6. How much time delay?
  7. Is this a sudden change in the normal operation of this pump?
  8. If so, what is the usual time to reach the desired pressure?
Are you absolutely SURE that the time delay is caused by vapor accumulation? If so, what makes you think so?
03/12/2012 10:28 PM
My comments are as follow:
1. Air is accumulating in recycle line since it is not completely dip in lube oil console from where the pump is taking suction.
Actually oil is not filling the line above the level of oil in the console as shown below which result in air accumulation.
2.Discharge pressure is 12 kg/cm2.
3.Time delay is of 90 sec.previously pump instantly achieve its desire pressure of 12 kg/cm2.
4. Yes we sure that air is accumulating in the line.
Hope my point is clear now.
aleeehsan@gmail.com
03/12/2012 11:32 PM
Your picture is not viewable!
Save the image to your hard disk. Then click on the icon in the message editor to browse, find the image, and upload it. Direct copy and paste does not work so well; variable results depending on which web browser you are using.
Make sure image format is .bmp, .jpg, .gif, or .png. Those will all upload and be viewable.
I am going to bed shortly and may not get back to you until tomorrow.
03/13/2012 11:08 AM
Hi Mikerho!
Configuration of pump is shown above.
We are sure that oil/air vapors are accumulating the recycle line.
We run the pump several times by keeping its discharge valve closed.
On 1st attempt, time taken by the pump to achieve its desire pressure of 12 kg/cm2 was 90 sec which reduced to 25 sec in 2nd attempt. On 3rd attempt pump instantly attained its final pressure, which shows that oil vapors are accumulating the line.
Temperature of oil console is around 62 0C.
Hope now the attachment is visible to you.Waiting for your comments on that.
aleeehsan@gmail.com
Good Answers: 19
07/11/2012 5:00 AM
http://www.google.com/patents?id=95kJAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
Good Answers: 19
03/13/2012 1:31 AM
Have you considered installing water Air Eliminators?
07/11/2012 3:38 AM
Sinobaler Machinery - a Manufacturer of baling machine for recycling industryProvide best baling machine!
Protect the environment, save the resources, start now!
Vertical baler: http://www.sinobaler.com/baler-type/vertical-balers/
Carboard baler : http://www.sinobaler.com/baler/cardboard-balers/
Bottle baler: http://www.sinobaler.com/baler/recycling-equipment-bottles-and-aluminum-cans-baler/
Textile baler: http://www.sinobaler.com/baler/lifting-chamber-baler-textile-baler-series1/
Drum crusher: http://www.sinobaler.com/baler/drum-crushers-balers-barrel-flattener/
Automatic horizontal balerhttp://www.sinobaler.com/baler/fully-automatic-horizontal-baler-2/l baler:
All kinds of baling machine for different applications.
Choose Sinobaler, Save your cost!
www.sinobaler.com
Register to Reply 7 comments
ali ehsan (2); ducon (2); Mikerho (2); Sinobaler (1)
