Previous in Forum: How are Gasket Sheet Made   Next in Forum: Side Crack On the Hot Rolled Steel Plate Edge
11 comments
Polysulphide Sealant
03/15/2012 9:36 PM
Hello,
I came across a two parts polysulphide sealant (PS) product which mixing ratio is 10 (resin):1(hardener). The set time is about two hours with Shore A value of at least 50. Question 1: Is this acceptable value range? Question 2: If after set time or a few years period, the PS is still wet-look and soft, could this due to incorrect mixing of the two parts, may be less hardener?
thanks
Best Wishes
Noel
Wish you luck on your search.
Re: Polysulphide Sealant
03/15/2012 9:47 PM
Years?????
Did you heat cure it?
Incorrect ratios, old, out-of-date material, poisioning of catalyst all may be a factor.
Give much more specific information about this uncured batch.
Have you tried a test batch???
More info....................................
What about manufacturers name and product information?
03/15/2012 11:10 PM
Hi Lyn,
It is 11-12 years old. Corrosion found on the mable fixture due to water leakage through the sealant.
I do not know whether it is heat cure, out of date material, as there is no record.
What is posioning of catalyst ? Will this affect the curing process and how to determine this problem. This happen on all sealant joints.
As it has been more than a decade, the design drawing specified Polysulphide Sealant and understand the product is likely supplied by Yokohama.
Question: What chemical can assess whether the material seen is polysulphide sealant?
Pls advise. thanks
03/15/2012 11:20 PM
Does it really matter? It has likely "reverted" (de-polymerizied) and is turning back into a soft state. Time, humidity and heat are enemies of this polymer. Polysulfide is brown, but may have been tinted with carbon black.
It should be removed and replaced with a modern sealant.
As the name suggests it may smell like sulfur.
03/16/2012 7:08 AM
I think someone goofed.
It looks to me like someone used a 1 part asphalt roofing compound that is designed to seal roof penetrations. It is also designed to form a thin skin on the outside and remain soft underneath.
Rather than trying to remove it, my advice would be to use a tool to push it further into the cracks, carefully clean the edges of the grooves with solvent, and recaulk with a moisture cure polyurethane caulk. It will last decades.
SikaFlex has some great products.
http://www.sika-distributor.com/sika-joint-sealants-waterproofing.html
Here's a distributor in Singapore:
http://www.aquaintl.com/sikaflex.html
Good Answers: 179
03/16/2012 9:01 AM
I agree with Kram, replace it...
Note: Don't get a newly mixed batch of polysulphide sealant on your hands or your clothes. It'll take forever to wear off your skin, whereas it'll never come out of you clothes (you might as well throw them out)!
Good Answers: 120
03/16/2012 10:52 PM
remove the old sealant, replace with true silicone sealant. It comes in tubes and also 5 gallon buckets, but it cures with air born moisture and comes in several colors. Depends on how much you need. Perhaps a few tubes will do. The 5 gallon bucket must be used once opened. You can also buy larger tubes. Try Home Depot
The polysulphide was cheaper back in those days, but now all the silicone patents are gone and silicone is far better.
Per Ardua Ad Astra
03/16/2012 11:16 PM
No. Not silicone!!!
If and when it does fail.........................which it will..................the silicone will be permeated into the stone. Anything that is used in the future, (including more silicone), is destined to fail. It won't stick.
There is a time and a place for silicone...................this isn't it.
Good Answers: 120
03/17/2012 9:47 AM
I have had great success with silicone, many of my uses will outlive me and I installed them 30 years ago. As to adherence, you have to prepare the old silicone properly and use a bridging agent like sil-net or sil-fix
Per Ardua Ad Astra
03/17/2012 10:53 AM
I've had success with it too, but there are far superior products (IMO) for filling joints in stone work, that are specifically designed for the job. Tooling is much easier too. Along with having a variety of colors available, the aesthetics of the finished product will much better than using silicone.
I have to admit though, as a person that applies paint for a living, my hatred for silicone is probably stronger than my love for it. Show up at an automotive paint shop with an open tube of silicone caulk and you're liable to get shot.
03/16/2012 11:21 PM
10/11/2021 4:20 AM
<...Question 1: Is this acceptable value range?...>
To whom? In connection with which standard?
Register to Reply 11 comments
aurizon (2); CaptMoosie (1); kramarat (3); lyn (3); noelngke (1); PWSlack (1)
