Previous in Forum: Looking for a High Pressure/Low Volume Pump Used in a Harsh Environment   Next in Forum: Prevent Shaft Bending
9 comments
PROPERTIES OF WATER
03/16/2012 1:48 PM
please, where can I get table about properties of water at various temperatures from 40 to 540 F. Just in case somebody has one, could you please send a copy?
Tanks in advance, best regards
Pathfinder Tags: properties of water
Re: PROPERTIES OF WATER
03/16/2012 1:52 PM
Is this Wikipedia article what you are looking for?
[edit] Looks like lyn or phoenix911 may have it covered.
03/16/2012 1:53 PM
I have used this often:
Water and Steam Properties (WaSP)
http://www.katmarsoftware.com/
03/16/2012 3:04 PM
03/16/2012 3:11 PM
uhhm, the power of google.
03/16/2012 10:18 PM
Table below may help you.
Some common used thermal properties for water:
Maximum density at
4 oC - 1,000 kg/m3, 1.940 slugs/ft3
Specific Weight at 4 oC - 9.807 kN/m3, 62.43 Lbs./Cu.Ft, 8.33 Lbs./Gal., 0.1337 Cu.Ft./Gal.
Freezing temperature - 0 oC (Official Ice at 0 oC)
Boiling temperature -
100 oC
Latent heat of melting -
334 kJ/kg
Latent heat of evaporation -
2,270 kJ/kg
Critical temperature -
380 oC - 386 oC
Critical pressure -
221.2 bar, 22.1 MPa (MN/m2)
Specific heat water -
4.187 kJ/kgK
Specific heat ice -
2.108 kJ/kgK
Specific heat water vapor -
1.996 kJ/kgK
Thermal expansion from
4 oC to 100 oC - 4.2x10-2
Bulk modulus elasticity - 2.15 x 109 (Pa, N/m2)
Thermal properties of water:
Temperature
Absolute pressure
Density
Specific volume
Specific Heat
Specific entropy
- t -
- p -
- ρ -
- v -
- cp -
- e -
(oC)
(kN/m2)
(kg/m3)
10-3 (m3/kg)
(kJ/kgK)
(kJ/kgK)
0916.8
(Ice)
0.010.6999.81.004.2100
40.91000.0
(maximum density)
50.91000.01.004.2040.075
101.2999.81.004.1930.150
151.7999.21.004.1860.223
202.3998.31.004.1830.296
253.2997.11.004.1810.367
304.3995.71.004.1790.438
355.6994.11.014.1780.505
407.7992.31.014.1790.581
459.6990.21.014.1810.637
5012.59881.014.1820.707
5515.79861.014.1830.767
6020.09831.024.1850.832
6525.09801.024.1880.893
7031.39781.024.1910.966
7538.69751.034.1941.016
8047.59721.034.1981.076
8557.89681.034.2031.134
9070.09651.044.2081.192
9584.59621.044.2131.250
100101.339581.044.2191.307
1051219541.054.2261.382
1101439511.054.2331.418
1151699471.064.2401.473
1201999431.064.2481.527
1252289391.064.261.565
1302709351.074.271.635
1353139311.074.281.687
1403619261.084.291.739
1454169221.084.301.790
1504779181.094.321.842
1555439121.104.341.892
1606189071.104.351.942
1657019021.114.361.992
1707928971.114.382.041
1758908931.124.392.090
18010008871.134.422.138
18511208821.134.452.187
19012608761.144.462.236
19514008701.152.282
20015508641.164.512.329
2208404.63
22525508341.204.652.569
2408144.78
25039907991254.872.797
2607844.98
27559507561.325.203.022
30086007141.405.653.256
325121306541.536.863.501
350165405751.7410.13.781
360186805281.9014.63.921
Good Answers: 179
03/17/2012 10:08 AM
Any good Thermodynamics textbook...or a good engineer's field pocket reference.
Muskesh gets a GA from me.
03/17/2012 12:31 PM
You can buy a copy of a set of Steam Tables, Boss, or you might be lucky to find a set on the world-wide-wibbly-wobbly-web.
Good moaning!
Register to Reply 9 comments
Anonymous Poster (1); CaptMoosie (1); Crabtree (1); Doorman (1); lyn (1); Mikerho (1); Mukesh0861 (1); phoenix911 (2)
