Previous in Forum: Designing an Electric Circuit   Next in Forum: Voltage Law
DC HV Testing
03/17/2012 8:12 AM
WHy DC high voltage test devices always generate negative voltage rather than positive voltage ?
Pathfinder Tags: DC High Voltage
Re: DC HV Testing
03/17/2012 8:20 AM
Where did you get that idea?
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Re: DC HV Testing
03/17/2012 9:43 AM
When you are doing a DC HV test, you are applying more than 2 time of rated voltage and this will provide over stress for cable. If it is a new cable, slowly we are destroying the insulation by applying HV DC. For example consider the case of cables. If we are applying positive DC Voltage, the stress because of the electric field will be radially outwards as shown below. Simply radial tensile force.
But if you are using negative DC voltage the stress devoloped due to electric field will be radially inwards. That is radial compressive force.
All materials having a capacity to withstand more compressive stress than tensile stress. In this way we can protect the good cable. But anyway week points will get break, if it is there.
This is the simple reason that negative DC is good for High Voltage testing.
If you can't find a way, make one........
Re: DC HV Testing
03/17/2012 10:44 AM
A short in the wire to ground will negate the test results using pos voltage...
Good Answers: 32
Re: DC HV Testing
03/17/2012 6:46 PM
Free electrons?
Positive charge is deficit of electrons and is easily neutralized by free electrons and it is difficult for the negative charge to go away under free electrons around.
Usually floating supplies are used so polarity hardly matters.
Register to Reply 4 comments
JohnDG (1); justinanto1987 (1); Shyam (1); SolarEagle (1)
