Previous in Forum: Carbon Dioxide and Sewage   Next in Forum: Best Practices - Technical Investigation Tracking & Communication Forms...
22 comments
How Do You Store Your Spec Information?
03/21/2012 9:43 AM
We (here at GlobalSpec) are curious how you keep track of all the products/components/parts you have used over the course of your projects? Do you use your logbook? A specbook? Some self-made system? This is a burning question for us right now - help us out! Thanks!
Re: How do you store your spec information?
03/21/2012 9:57 AM
Excel
03/21/2012 11:10 AM
ditto,
REQ orders for the actual purchased parts
Re: How Do You Store Your Spec Information?
03/21/2012 10:23 AM
Granite and chisel. The data density factor is low but when amortized over the length of retention this is the most cost effective method. At least that's what our bean counters are dictating. Stupid bean counters.
03/21/2012 10:28 AM
Also Excel - with hyperlinks to spec sheets, photos or whatever.
03/21/2012 11:11 AM
I tryed the hyperlinks, if there are any files on the computer or if one link is broken, they all become broken.
03/21/2012 12:21 PM
Not in my experience. I've used the technique for my job directory and my order book since 1999. Some sheets have upwards of 500 links - if the target of one link can't be found, it doesn't affect any of the others.
The only big drawback I've found is that if, for instance, I rename or move a folder (say a folder full of .dwgs), then I have to edit every link to the files in that folder. Since my main drawing folder has about 150 sub-folders (for individual jobs), each with anything up to 100 drawing files individually linked to from at least one spreadsheet, it can take days - if not weeks - to get all the links working again.
I've been dabbling with ways of automatically locating all the links and modifying them, but without much success (yet!).
03/21/2012 1:13 PM
I take that back, we had updated our LAN (three times in less than a year, nephews of the owner of the company were playing IT wannabes), and we (I) had to rename the target in the links. The first (2) times I updated the links, the third time I couldn't, I turned it over to the IT department, but they were out on their jet skis.
I also had it linked the drawing files, quotes, scope of the projects. I can't remember but it was well into the thousands projects (over 5 years worth).
Very efficient.
There is a way to displaying formulas in excel, I wonder if there is a way of displaying the target in the hyperlink. Then you copy ythe column in another sheet and do a global edit to change it if its just a drive or a directory (folder) change.
Then copy the column past to your achive sheet. ......as long as you don't insert a row in between while your doing it
Good Answers: 75
03/22/2012 5:51 AM
I use exactly the same as JohnDG, Excel with images where applicable, links to suppliers, part numbers, quantities required, prices, etcetera.
I've also had no problems with broken links so I don't think that problem lies with Excel.
As for the problem of renaming a folder and having to update the links I'm sure that with some Visual Basic add on to Excel you could solve the problem relatively simply.
03/22/2012 10:04 AM
Prompted to do a bit more fiddling, I've found an expression in VBA to access a hyperlink target address, e.g.:
Sheet6.Range("G4").Hyperlinks.Item(1).Address
which (in this particular case) returns:
../../../OrCAD_JDG/Projects/1246 CR4/1246E1.OPJ
so I think the rest should be pretty straightforward. I'll probably get round to writing a VB application to find/replace the target addresses (or parts of them) (one day ).
03/23/2012 10:14 AM
A bit more fiddling:
Private Sub UserForm_Click()
Dim i, t
t = ""
For i = 1 To Sheet6.Hyperlinks.Count
t = t + Sheet6.Hyperlinks.Item(i).Address + vbCrLf
Next i
TextBox1.Text = t
End Sub
The above will find all the hyperlinks in the sheet, and display a list of the targets in a textbox.
Good Answers: 58
03/21/2012 10:33 AM
We use a system similar to "Tool Tracker".
It tracks the the materials/components/parts/tools/equipment we use on any particular project and is searchable using the project name, engineers name, end users name, project description, product description, product UPC code, product part number, tool or piece of equipment used.
Being that the majority of our projects are industrial, institutional and/or municipal, we usually just follow the project specifications created by the project engineer which vary from project to project.
In the rare event that specifications are not generated for a given project, we look up a similar project in our database and go by the information available.
03/21/2012 11:31 AM
I keep all my various data in a separate DATA folder that is backed up overnight to my other computer. Inside this folder I have specific folders for Projects, Finance, House, Health, etc. Any info, manuals, component specs, etc. are then stored in their own folder.
In some cases, such as reference manuals or spec sheets, I'll use Excel with hyperlinks to specific documents.
Overall, my tool-of-choice is Excel.
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
03/22/2012 8:12 AM
We are installing a new software - sharepoint. I am thinking this may be useful. Don't know yet, but sounds good. Anyone tried this yet?
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
03/22/2012 6:44 PM
Our company is in the process of installing it. The Design Standards are slowly migrating to that system. Unfortunately, this means that the logical indexing system will be lost.
Chaos always wins because it's better organised.
03/23/2012 8:54 AM
hope your company has training
Good Answers: 75
03/23/2012 10:44 AM
Training? What's that? Surely the 10 minute "it remembers the last three versions is all we need?? IT can be trusted to make sure it's all smooth and seamless....
03/23/2012 10:47 AM
your tagline is pretty fitting.
03/22/2012 8:46 AM
A controlled database is the most efficient way to manage, track and maintain a products/components/parts resource. Too often, I find organizations that allow each engineer to keep his/her own item resource. Then drafters are lost in the sea of description insanity; Screw, threaded 1/4" OR 1/4" Threaded Screw. Additionally each line/character in a bill of material is hand jammed. STOP THE INSANITY!
Hello.....today's HMIs/databases can automate this process and save hundreds of hours in typing and QA. I have kept track using resources labeled NAVISION (SAIC) or Costpoint.
Yes, it will take some resource to develop such an item database and yes it has upfront cost to implement.
Develop/enter the product/component/part ONCE then drag and drop (auto-fill) the item once in the BOM instead of hand jamming hundreds of times in multiple assembly drawings. The database maintains, datasheet, approved description, where used, cost, etc. Also maintain control of items. Yes a component engineer. Management of this resource includes reviews for part obsolence, part alternates, reliability, etc.
03/22/2012 10:45 AM
Here at work we use Sharepoint. I myself use a document management system called M-Files.
Works great linking all related information for a specific project together (emails, photos, Drawings/Models, Change Orders etc.). It also works seamlessly with MS Office and various other CAD/CAM packages.
Mike
03/22/2012 1:26 PM
For those of you that mentioned Tool Tracker...is that the software by Waterwheel? I'm trying to look it up. Thanks!
Good Answers: 58
03/22/2012 5:33 PM
My life is simple. I use 'Favorites'. I generalize subjects, and make folders, so it all fits on the screen at one time.
For things that are not online, I use 'Shared folders' and 'Shared pictures'.
Through careful subject groping and using folders, I can get a lot of stuff on one screen.
In other words, I use my computer.
mike k
Good Answers: 75
03/22/2012 7:13 PM
The Purchasing/Procurement Depsatment and Design Office are the appropriate locations for spec details of items used in products. The best place to keep the information, and this will also help with ISO9001 and TS16949 audits, is in the PPAP file.
Our Purchasing Department holds the PPAP files, as part of the supplier development brief. Supplier part numbers and defining characteristics are also recorded in the drawing models and in the business system.
Of course, we engineers also have our files (both electronic and paper), organised by project. We tend to refer to these for details of things we don't use...
Finally, the best list to keep is that of suppliers - so you can always be sure you're ordering their latest model.
Register to Reply 22 comments
dgibson (1); English Rose (3); Graebeard (1); JohnDG (4); KJK/USA (1); masu (1); memiles47 (1); mike k (1); Old Coal Man (1); phoenix911 (5); redfred (1); szwasta (1); Tina Streett (1)
